68 brake calipers
Old Jun 5, 2017 | 01:54 PM
68bigblock's Avatar
68bigblock
Default 68 brake calipers
I just pulled off all four brake calipers. I'm considering rebuilding with stainless steel sleeves. I heard there is someone or company in Florida that provides this service. Can anyone make a suggestion? Any idea of the cost? Also, I have read there is an upgrade to o-ring style calipers from the factory style lip seals. Is this the way to go?
Thanks in advance!
Old Jun 5, 2017 | 02:05 PM
Mr D.'s Avatar
Mr D.
For normal driving and braking I just use O'Reilly, $68.99 with a Lifetime Warranty.
Old Jun 5, 2017 | 02:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You're not limited to a specific company. Almost all the Corvette vendors carry stainless steel sleeved calipers, usually with exchange of your originals for cores. O-rings are also an option.
Old Jun 5, 2017 | 02:26 PM
68bigblock's Avatar
68bigblock
Maybe I was not clear. I'm considering getting mine rebuilt and keeping the original. Should I get them rebuilt with o-rings? Any idea of the cost?
Old Jun 5, 2017 | 02:38 PM
Mr D.'s Avatar
Mr D.
Corvette Caliper Rebuilding & Restoration
We provide complete caliper rebuilding and restoration for all Corvette model parts. Once we receive your Corvette calipers, they are cleaned, bored, stainless steel sleeved and rebuilt using OEM parts. External castings are painted with a GM flat grey primer. Calipers are tested and returned to you 100% ready to bolt on your Corvette.
Lifetime warranty on the stainless steel sleeves; one year warranty on rubber components.
1965-1982 4 Piston Corvette Calipers $89.00
Approximately 4-6 week turnaround
Mr D.'s Avatar
Mr D.
Google corvette caliper rebuilding
Old Jun 5, 2017 | 04:59 PM
68bigblock's Avatar
68bigblock
I found the company in Florida that does the work. Precision Engineering. Five business day turn around.
To 68 brake calipers
