Front caliper spring ID (pictures)?
Old Jun 7, 2017 | 08:16 PM
Lyndwood's Avatar
Lyndwood
Default Front caliper spring ID (pictures)?
I had a leak on one of my previously rebuilt front calipers (front washer between the halves on the end), so I decided to pull both calipers and rebuild them with an up graded o-ring kit.
after taking apart the 2 calipers (both previously replaced by the last owner) one had what I would call "Normal" springs, the other had elongated springs that had obvious differences than the first set. I had another doner front caliper available so I pulled it apart and it had the "normal" size springs in it.
my question is why is this set of springs so different and should I re-use them or use the other set of "normal" springs so they (both sets) have matching spring rates?
longer one on the left and normal one on the right
Old Jun 8, 2017 | 12:25 AM
henrikse's Avatar
henrikse
look like the same spring but one somebody stretched out to get more tension.
Old Jun 8, 2017 | 12:45 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Maybe one puck was sticking/stretching the spring was previous owner's way to solve the problem?
(Didn't GM develop O-rings in the 1980s that retracted the puck slightly to prevent the pads from dragging on the rotors?)
Old Jun 8, 2017 | 06:43 AM
Rotonda's Avatar
Rotonda
Why not put fresh ones in? They only cost $3 to $4 each from vb&p or Cssb. It's little enough to assure that you have good consistent brakes. You've already invested a lot of time in fixing them.
Old Jun 8, 2017 | 07:42 AM
Brooklinite's Avatar
Brooklinite
With o-rings you can ditch the springs. They fit tight enough in the bore that the spring won't move them.
Old Jun 8, 2017 | 08:37 AM
gbvette62's Avatar
gbvette62
Springs aren't used with O-ring seals.
Old Jun 8, 2017 | 09:49 AM
hicswa's Avatar
hicswa
No spring needed.
Old Jun 8, 2017 | 03:30 PM
Rotonda's Avatar
Rotonda
If that is the case why do the O-ring calipers I am rebuilding have springe? AND why do the O-ring kits I am installing also have springs?
If the OP is interested, I will send him the springs I removed for the cost of shipping. PM me if interested.
Old Jun 8, 2017 | 04:50 PM
Lyndwood's Avatar
Lyndwood
I have new springs for 2 calipers, I just wanted to know why there were 4 odd springs in one of the calipers I took apart. I thought they were stock springs as well that were stretched out but the 4 odd ones actually have a smaller ring diameter on the end coil and a slight bulge in the center as compared to a stock one?
I am intrigued by the statements of not using the springs with a new o-ring up grade kit? So when I rebuild these I should not put the springs back in at all?
Old Jun 9, 2017 | 04:11 AM
terrys6t8roadster's Avatar
terrys6t8roadster
O-ring kits = no springs. T
To Front caliper spring ID (pictures)?
