Help!!!!
Old Jun 9, 2017 | 03:59 PM
mk's78's Avatar
mk's78
Default Help!!!!
Hey the folks and C3 gurus....
Just changed out a set of squealing rear brake pads and that cured the squeak and squal but now my brake light is on and after several test drives and breaking it will not go off?????
All help, tech advice etc is most certainly needed..
Thanks all!!!!!
mk's78
Mike
Old Jun 9, 2017 | 05:56 PM
Street Rat's Avatar
Street Rat
Go online and search for POL prop valve tool. Use this tool to hold your proportioning valve internals centered while you bleed the brakes. This inexpensive trick works great.
Old Jun 10, 2017 | 02:14 AM
Z06LMB's Avatar
Z06LMB
Thanks Mr. Rat!
I've been bleeding my brakes for many years and never knew this tool existed. The way things work I'll probably need one on the next bleeding. Is this a universal tool? Are proportioning valves all the same to use this tool?
Rich
Old Jun 10, 2017 | 08:30 AM
Street Rat's Avatar
Street Rat
Originally Posted by Z06LMB
Thanks Mr. Rat!
Rich
This tool fits the GM prop valves.
https://www.performanceonline.com/Co...ve-Bleed-Tool/
To Help!!!!
