69 speedo cable routing
Old Jun 25, 2017 | 06:39 AM
68notray's Avatar
68notray
Default 69 speedo cable routing
On my 69 the speedo cable comes out of the passenger rear of the Muncie tailshaft. Then it could go over the top of the trans OR under the trans headed to the firewall. Which is correct?
Old Jun 25, 2017 | 10:53 AM
TimAT's Avatar
TimAT
From the speedo, it runs to the right and thru the firewall, across the back of the engine over the bellhousing, drops down along the right side of the tunnel and back to the trans. I routed mine over the heatshield to help keep it close to the body under the passenger side floor.
Old Jun 25, 2017 | 10:56 AM
redbarchetta74's Avatar
redbarchetta74
I can confirm this as I just replaced my speedo cable yesterday and routed exactly as described. I believe you'll also see a couple of hooks/clips along the way where the cable can clip into.
To 69 speedo cable routing
