need help with 68 steering column
Old Jun 25, 2017 | 06:16 PM
live4corvette's Avatar
live4corvette
Default need help with 68 steering column
I have successfully changed my manual steering to Borgeson power steering, or at least almost successfully. I replaced the upper and lower bearings and shortened the column shaft as recommended by Borgeson. Unfortunately, I damaged the upper bearing retaining ring during disassembly and cannot find one anywhere. Does anyone know where I can get a new retaining ring? I am also having an issue with the upper bearing not staying in the housing. I have read a few threads about guys having to epoxy them in or try to pinch the race in place. I am ready to try epoxy if I can find the retaining ring. Please help!
Old Jun 26, 2017 | 11:24 PM
mark6669's Avatar
mark6669
67 columns are the same as 68's, LI Corvette part #18-21D I think is what you need.
Mark
Old Jul 5, 2017 | 07:20 PM
live4corvette
Mark
Thanks Mark. I bought an assortment of external snap rings at the local hardware store and found one that will work. I think I am back on track.
To need help with 68 steering column
