c3 expansion tanks
Old Jun 26, 2017 | 12:26 PM
xpoc454's Avatar
xpoc454
Default c3 expansion tanks
I was reading online that the 68-72 big blocks all had an expansion tank. Either the silver aluminum one or the brass one for AC cars.
Why did they have them in the first place?
Is it because of the mounting angle of the radiator?
Do any other cars have this expansion tank also?
All the classic cars I had all had a radiator cap on the radiator.
thanks, was just wondering
jim
Old Jun 26, 2017 | 12:40 PM
MelWff's Avatar
MelWff
The BB tended to run hotter, the tank increased cooling capacity and removed air pockets in the radiator.
Not clear what you mean by "other cars", other manufacturers?
Old Jun 26, 2017 | 01:41 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
All radiators need an expansion tank. Most of the time the tank is an integral part of the radiator, thus the pressure-rated cap is on the radiator. Big block and high performance small blocks needed more square inches of radiator tubes to dissipate the engine heat generated. There was no room on top of the radiator so the tank with cap was remotely located. That is my story and I'm sticking to it.
Old Jun 26, 2017 | 03:16 PM
xpoc454's Avatar
xpoc454
Yes I was asking about other Chevrolets or other big block cars from the era from that time period.
Old Jun 26, 2017 | 03:23 PM
MelWff's Avatar
MelWff
All radiators need an expansion area, not necessarily a tank. The corvettes without a tank had a radiator fill line about 2" below the neck thus the top rows of the radiator were the expansion area. No other GM cars used tanks, they did have expansion areas, until 1973 when they went to a sealed radiator cap and return bottle.
To c3 expansion tanks
