C3 Front Springs
Old Jun 30, 2017 | 02:42 PM
Timog156's Avatar
Timog156
Cruising
Default C3 Front Springs
Can someone tell me the difference on front springs between Big Block & Small Block??
Thanks in advance
Timo
Spring size/color/length
Last edited by Timog156; Jun 30, 2017 at 02:47 PM. Reason: I didn't leave enough info
Old Jun 30, 2017 | 02:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rating. Big block springs are stiffer to accommodate the additional weight of the big block.
Old Jun 30, 2017 | 08:40 PM
MelWff's Avatar
MelWff
if you need detailed information for a particular year try this site
https://www.gmheritagecenter.com/gm-...tion-kits.html
Old Jul 4, 2017 | 07:13 PM
Timog156's Avatar
Timog156
Cruising
I found a guy that has a corvette bone yard. He has a bunch but doesn't know the difference between small block & big block. Wondering about Spring size, Color, Number of springs
Old Jul 5, 2017 | 09:09 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Timog156
...I found a guy that has a corvette bone yard. He has a bunch but doesn't know the difference between small block & big block. Wondering about Spring size, Color, Number of springs...
Originals had identifying tags on them. If the junkyard owner is pulling springs for anything after 74, they are not big block springs.
Old Jul 6, 2017 | 12:50 PM
Frank_Nesta's Avatar
Frank_Nesta
Just a thought. Not knowing what you are trying to accomplish. Once you have the car apart enough to replace the springs. I would replace the springs with new springs so that you know what your dealing with. 2 spring from unknown vehicles might give you different results at each wheel?
To C3 Front Springs
