T5 and Parking Brake Cable
I am installing the parking brake system and now the cable that comes from the handle is too close to the U joint and yoke, it hits slightly.
I had to relocate the pulley from between the ears of the bracket to the outside of the bracket toward the passenger side. I used a longer bolt and filled the gap between the bracket ears with washers to make it solid. It all clears now and seems like it will work.
I was just wondering if anyone else has run into this problem and if so what was your solution?
Thanks in advance
Mark Potter
Sounds like you are in good shape now Mark, enjoy it.
