By pass heater core
Old Jul 16, 2017 | 06:15 PM
548Smit's Avatar
548Smit
Default By pass heater core
I would like to know how to by pass the heater core as the copit get hot even with heater switch in the off position, some one said to put a shut off valve in the 5/8 s side of the water line, will it cause a problem with the remanding flow of antifreeze. It's a 77 with air.. Also would like to know is it possible to drop a 502 big block in how much work is involved, Any one that does the engine installation in south jesery
Old Jul 16, 2017 | 07:47 PM
sunflower 1972's Avatar
sunflower 1972
Search is your friend. There are plenty of posts on this topic.
Old Jul 17, 2017 | 09:35 AM
Street Rat's Avatar
Street Rat
Here is one link...
https://www.corvetteforum.com/forums...off-valve.html
And a picture of my set up...
Old Jul 17, 2017 | 12:50 PM
BKbroiler's Avatar
BKbroiler
No bypass is needed at all. Get pipe plugs, one for the water pump heater hose connection and one for the intake manifold - two different sizes. Eliminate the hoses entirely. I did this on my 77 years ago.
Old Jul 17, 2017 | 01:24 PM
John 65's Avatar
John 65
I used the same shut off valve like Street Rat did and it works great.
It's very ez swapping in a BB engine. I put one in my 77. For the most part it's pretty much a bolt in, nothing high tech about it.
Upgrade the cooling system and obviously a different exhaust, along with all the BB brackets and pulleys. Good news is the stock springs, if in good shape and the stock hood works fine.
Old Jul 17, 2017 | 03:42 PM
dochorsepower's Avatar
dochorsepower
I've had mine plugged for over 20 years. Saves that heat circulating thru interior.
To By pass heater core
