Y'all like my models?
Old Jul 17, 2017 | 04:49 AM
'82collectoredition's Avatar
'82collectoredition
5th Gear
Default Y'all like my models?
Not that good at making models but I'll get there!
Old Jul 17, 2017 | 05:39 AM
billcarson's Avatar
billcarson
very nice! how do you make them and out of what materials?
Old Jul 17, 2017 | 07:03 AM
'82collectoredition
5th Gear
I just bought plastic model kits online and use testors model paint with different brushes and also an air brush. I'm working on a '53 Vette currently. It is a very fun hobbie!! Mabye I should build a different car other than Corvette
Old Jul 17, 2017 | 09:34 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
"It must be nice owning that my Corvettes!"
Old Jul 17, 2017 | 03:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by '82collectoredition
...I'm working on a '53 Vette currently...
Which kit? Monogram or AMT?
Old Jul 17, 2017 | 04:18 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old Jul 17, 2017 | 04:19 PM
ed427vette's Avatar
ed427vette
Here is a quick pic of some 1/24 scale corvettes in my collection. They are resin kits.
Old Jul 17, 2017 | 05:38 PM
billcarson's Avatar
billcarson
very nice hobby and easier than struggling with trailing arms.
Old Jul 17, 2017 | 07:32 PM
JayRay's Avatar
JayRay
I feel the same about my 1:1 1977 Corvette
Building Models actually pushed me into trying the full size version.
Old Jul 17, 2017 | 07:35 PM
'82collectoredition
5th Gear
Amt
Old Jul 17, 2017 | 11:20 PM
terry82's Avatar
terry82
I used to enjoy building all kinds of models .fun hobby.i still have a few cars and the invisable v8.
Old Jul 18, 2017 | 12:40 AM
TCracingCA's Avatar
TCracingCA
The Aardvark SS looks great! I am still trying to figure out what color to use to get it as perfect as yours! The two Stingray Racer- I forgot who did that kit (I have one) and it is basically just two styrene half shells, so you have done some scratch building! Cool! The GT-40 looks to be straight out of the Monogram box, but you said Resin??? Thunder Valley or LeMans Minatures maybe? and the Tipo 61 Maserati I think is another rare Aardvark kit!
Just a taste. Thanks for sharing!
Old Jul 18, 2017 | 12:51 AM
TCracingCA's Avatar
TCracingCA
Not necessarily so!! I could have 20-30 hours into building just one car or even more! I can professionally assemble any plastic kit to a high quality in about 5 hours straight no mods or customizing, not counting drying time!
Old Jul 18, 2017 | 01:00 AM
TCracingCA's Avatar
TCracingCA
It can be addictive! Nice start!!!!!!
You will be drilling distributers for plug wires, adding carpeting, and sanding out the rubber tires for a more realistic look in no time!
The coolest is getting a real spray can automotive high end acrylic Laquer primer and getting the authentic colors from the real paint stores!
Some tips
I will get a pair of wire snips and cut the spruce apart by what color I plan to paint a group of parts! I put some alligator clips in the end of sticks to hold the spruces while I spray paint! Then after painting let the parts dry and then carefully cut the dry parts out onto a tray to not lose any! One parts at a time I scrape carefully the gluing surfaces to the bare spruce! Then I glue assemblies, and then do the brush touchup of where the spruce was cut! For assembly, minimal glue! The liquids brush type dangerous for beginners, because it will ruin paint! I use testors liquid with the needle applicator tube! And I use epoxies and super glue for some things! Like when attaching a mirror, I will drill a small hole in the body and one in the mirror and super glue in a piece of rod spruce or wire and then a tiny bit of epoxy on the wire sticking out and superglue on the end of the wire to give the part attachment strength. I use like foils for mirrored surfaces! I use a fabric tape to make belts, pulleys after cutting off phony badly cast ones! I like the Tamiya bottle paints for interior leather/vinyl. and will let a brush coat set up and then texture that with like a dry brush! I will Semigloss spray like chrome parts to give a more realistic finish, but I evolved into the real expensive metalizer paints! For the body I will remove it from the spruce and prep with 600 grit and an xacto blade! I will glue a spruce post on the inside roof and using one of my alligator clips to hold the whole body on a stick , start spraying! The body with primer! I will let prime dry for at least a day and any painted part even longer before handling! ! I will wet sand the primer with a 1200 grit being careful to not take it off the paint on corners or edges! I will dust coat lightly the entire body before making full even stroke paint rubs! I use elmers glue for windshields or carefully with epoxy small dabs! Etccetc etc etc etc etc etc
Old Jul 18, 2017 | 05:46 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
i"ld like to find a 1/16 kit for the winter. I nice relaxing build. I loved building them as a kid. I had the model T with the electric motor. I loved that thing
Old Jul 18, 2017 | 06:00 AM
oldgto's Avatar
oldgto
I haven`t seen any in a while.... but there used to be a garage with tools. It doubles as a plastic display case. (Sorry the car is not a Vette.) If you can`t find the garage, I think the tools are still out there. This is the only model I`ve done since I was a kid....
Old Jul 18, 2017 | 10:13 PM
ramair_bryan's Avatar
ramair_bryan
build a C-7 and fix the tail lights................
To Y'all like my models?
Old Jul 18, 2017 | 10:44 PM
C3 4ME's Avatar
C3 4ME
When I bought my '79, I remembered that I built a 1:8 scale 78 Corvette model as a kid and dug around in the attic and I found it. I always painted a date in a hidden part of every model I built I found a date of '82 on this one. I've told myself, one day I'm going to take it apart and paint it to match my 1:1 model.
Old Jul 20, 2017 | 12:09 AM
TCracingCA's Avatar
TCracingCA
Thats awesome! I still see garage equipment kits at like model expo, kit collector swaps and shows on occasion! You have a lot of good stuff in that diorama!
Old Jul 20, 2017 | 08:13 AM
billcarson's Avatar
billcarson
very nice stuff here and i stand corrected.
