Power Steering. Rebuild or replace?
Old Jul 17, 2017 | 05:48 PM
Norm07's Avatar
Norm07
Default Power Steering. Rebuild or replace?
I have done a search and no clear answer. I have very leaky power steering components. For those of you who have done it, would you rebuild again or just replace with vendor replaced rebuilds. I have heard when the rebuild is done by the regular guy, it's not reliable and you end up replacing. Anyone?
Old Jul 17, 2017 | 05:59 PM
biaggio's Avatar
biaggio
Check out VP and B website. They sell a brand new(not rebuilt) power steering control valve and a new(not rebuit) slave cylinder plus new power steering hoses. There parts are made of the highest quality, durable and long lasting. They cost more but you get what you pay for. Stay far away from new aftermarket parts that are made in China and will fail prematurely. Sure they cost less but there quality is quite poor and you will pay for it in the long run. Just my .02
Old Jul 17, 2017 | 06:02 PM
Mr D.'s Avatar
Mr D.
I would just buy rebuilt.
Old Jul 17, 2017 | 06:13 PM
V4motorsports's Avatar
V4motorsports
Buy the parts and rebuild them yourself. It really isn't that difficult.
YouTube is your friend!
Russ
Old Jul 17, 2017 | 10:13 PM
jlpskydive's Avatar
jlpskydive
Russ
Could you please hit me with those links.... about to start.
Holy crap never knew it was going to be this big of a project..... But here I am.
Old Jul 18, 2017 | 05:11 AM
V4motorsports
Power Steering Cylinder Ball Stud End Rebuild:
How To Replace Your C3 Corvette Steering Ram:
Power Steering Cylinder Rebuild:
Some that I used. Willcox also has a lot of useful videos.
Hope this helps.
Russ
Old Jul 18, 2017 | 08:03 AM
NONN37's Avatar
NONN37
I rebuilt the power cylinder and control valve. I bought cheap kits online i think i paid around 20 for each. and got new hoses at rockauto, and a steering pump with no can.
Nothing leaked or exploded when i started the car.
Be sure to lay out all the pieces in order of how they are assembled and how the hoses attach. clean everything really well and use the correct lubes to assemble. It is not too hard. I opted to get a rebuilt pump, seemed cheaper than rebuilding time for me. It also comes with seals to reuse your old can.
The tougher part was probably priming the system and adjusting the ram. but it wasnt difficult, you just need a little patience and extra fluid.
Old Jul 18, 2017 | 08:18 AM
Norm07's Avatar
Norm07
Have you decided where you are getting your rebuild kits? Or where you got them?
Old Jul 18, 2017 | 11:04 AM
Big2Bird's Avatar
Big2Bird
I used rebuilt control valves, and they just don't last.
I bought a brand new Lone Star valve, and drop free for years now.
Vb and p has a as sleeved ram I installed 10 years ago. Still works great. NO leaks. My 2 cents.
Old Jul 18, 2017 | 11:17 AM
REELAV8R's Avatar
REELAV8R
I rebuilt my control valve and power steering ram about 2 years ago, no leaks so far. Wilcox has an excellent you tube video that will walk you through the control valve rebuild.
I got the rebuild parts off of ebay.
Hoses I got from NAPA autoparts.
Pump was still good so didn't mess with it. Until recently when it decided to start leaking where the pump goes into the reservoir. So now the pump/ reservoir will be replaced.
Old Jul 18, 2017 | 12:12 PM
74Ken's Avatar
74Ken
ok I'll be the one guy that says REPLACE IT.
I replaced my control valve twice...that was it for me, went to Steeroids Rack and Pinion setup. Much better control and no drips.
Ken
PS. Of course, while I was at it, I dropped the oil pan, replaced the rear main seal, sand blasted the oil pan and repainted it, sanded all the frame parts that the Steeroids touches and painted them first, then smeared grease over the new paint to make it better.
Old Jul 19, 2017 | 07:07 AM
Norm07's Avatar
Norm07
Looks like I am going to go the rebuild(myself) route. Pump, steering box, cylinder shaft and control valve. Right now my biggest challenge is to purchase the right rebuild kits. It seems there is some duplication of parts when you are looking at the kits for the control valve. I will be doing some research and contacting Ecklers....I will post my findings...
Old Jul 19, 2017 | 07:18 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Step one, buy a lift. Just kidding. Ever notice that guys that recommend a rebuild have good access to the underside of the car? I speak from experience that having a lift makes this a much easier and safer job. Depending upon how much of the work you want to do yourself you can do any combination of purchase and rebuild. If time is an important element to getting it done and back on the road then balance that in the equation. All in all, have fun with it. Best regards, David
Old Jul 19, 2017 | 07:37 AM
SpiritOf76's Avatar
SpiritOf76
Subscribing to this one. I'm sure I'll need this info soon.
Old Jul 19, 2017 | 11:28 AM
OldCarBum's Avatar
OldCarBum
I'm planning to replace my OEM and go with the Borgenson unit, replace the 44 year old pump and replace the hoses. The Borgenson unit gets rid of two hoses and all the hardware hanging off the bottom of the car as well. I've heard nothing but good things about this mod.
Old Jul 19, 2017 | 11:44 AM
REELAV8R's Avatar
REELAV8R
I found the easiest access to the control valve and hoses is by taking off the left front tire.
Old Jul 19, 2017 | 05:36 PM
Norm07's Avatar
Norm07
I have a lift.....and....oh yes.....can't imagine doing the work without it And...I have the time....Retired...lifetime holiday with pay!
Old Jul 19, 2017 | 05:38 PM
Norm07's Avatar
Norm07
Motor and transmission are out....getting ready to remove the entire front suspension to replace all bushings etc...
To Power Steering. Rebuild or replace?
