'69 modded vert body on top of C6 Z06 platform
Old 02-21-2018, 10:15 PM
  #41
aussieross01
aussieross01's Avatar
Plan on using a C6 interior but more upmarket with quality leather dash, door trims, plus a smattering of carbon fiber
Old 03-01-2018, 06:29 PM
  #42
aussieross01
Default C36 Dash Build
Decided to run with C6 style interior with this build. It fits with our build plan, and by the time we finish, it should look pretty cool with our goals of using leather and carbon fibre in the finishing process.
We sourced a local RHD fibreglass dash shell, and cut it up to suit the fitment with the widened C3 windshield frame. Chopped off most of the front of it:- of course the C6 windscreen rake is huge when compared to the C3 we are using.
Pic 1 shows the fitting on the bare cut down dash, pic 2 shows the start of the process building with urethane foan. Real easy to shape this foam, and you can fibreglass right over the top.
Old 03-02-2018, 11:27 PM
  #43
aussieross01
cant imagine the hrs you got into that keep it up.
Yes, lot of hours, sometimes think a man is mad, but I'm retired, love the challenge, and can't think of anything else I'd prefer to be doing. It is also true there are some days, I hate the bloody car.
Good opportunity to spend time with your friends as well.
Certainly not a commercially viable build, and if you paid retail shop rates down here, it's better than $100 per hour. Must concede also, we're pretty darn slow these days.
Old 03-03-2018, 04:00 AM
  #44
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
8500 hrs times 100 bucks/hour. Just think how much that car will be worth!!
Old 03-03-2018, 06:03 AM
  #45
aussieross01
Hmm! Cost is one thing:- worth is something else entirely. We get it right, perhaps it will be worth a reasonable amount. On the other hand, if we get it wrong, it's worth the sum of the parts.
Old 03-08-2018, 08:17 PM
  #46
aussieross01
Dash taking shape.
took a 'quicky' mold from the front edge of a C3 dash pad at base of windshiled, and used that as a reference point to pick up the C6 RHD dash, styled it with foam, then bogged and smoothed to shape.
We will now give it one layer of glass, smooth out, then take a mold from it.
Old 03-20-2018, 12:08 AM
  #47
aussieross01
Pic showing metal fabrication for new front:-
1. internal metal front bumper support now a new custom unit
2. Front bumper is a cut and shut original
3. Grille surrounds, thou the same length are now 2" higher
4. Bumper over riders now also 2" taller
5. Grilles now all custom fabricated from flat aluminium bar
While it all looks reasonably stock in configuration, every thing is custom
Old 03-20-2018, 03:32 AM
  #48
doorgunner
Nam Labrat
Support Corvetteforum!
doorgunner's Avatar
Received 4,178 Likes on 2,738 Posts
NICE........very NICE!
Old 12-08-2018, 02:25 AM
  #49
aussieross01
Default Hey Guys, been a while, some updated pics.
Showing custom hood sub structure. Used original C6 rear hood subframe to pick up original rear hood latches. Raised outer front sections to pickup hinges for custom tilt front. This whole front section made from foam, the glassed over, and we use lots of plastic filler in this mock up process. Once completed mold will be taken off, for production of the 5 copies we need. Whole process, quite a 'mission'.
Rear mock up near completion. Originally going to run C3 LED tail lights, but given we widened the rear 9.5", they looked like 'peep holes in the snow'. Very happy with the C6 tail lights. Original 'corvette' script between lights gave way to C6 centre emblem. Original C3 bumpers had some surgery to fit. and mount close to the body. Lower valance modded from a glass copy of the original. Pretty happy with it, almost ready to flop a mold from this
Old 12-09-2018, 04:53 PM
  #50
Priya
Priya's Avatar
This is an amazing thread, I'm glad I found it!
Old 12-12-2018, 02:47 PM
  #51
Renatopazperu
Renatopazperu's Avatar
Awesome thread! Makes me want to go home and start creating something different on my C3. I quickly remember I could never get it to look that good. Great Job!
Old 12-12-2018, 07:37 PM
  #52
Rescue Rogers
Dementer sole survivor
Rescue Rogers's Avatar
Received 6,292 Likes on 3,919 Posts
2016 C3 of Year Finalist
thanks for the update
Old 12-12-2018, 08:10 PM
  #53
naramlee
naramlee's Avatar
this is FANTASTIC!!!!
Old 12-15-2018, 06:15 PM
  #54
aussieross01
Default working on tilt front hood hinges
Challenge here is to get front hinge assembly to come immediately up and then forward to clear front valance which stays in place like the C4. First time we are having to use a non corvette part. Scouring the salvage yards we found some hinges from a volvo p70, which so far, look like they will do the job. To make this easier, I just flopped a quicky short front from our mold. Plan on using linear actuators to open the hood. So far so good, will post operation when complete.
Old 01-11-2019, 06:14 AM
  #55
munro 2446
Cruising
munro 2446's Avatar
Looking good Ross.
Old 02-16-2019, 02:46 AM
  #56
aussieross01
9.5" wider, and 4" higher than a stock C3 at the rear. Surprisingly we thought the C6 tail lights looked a heap better than the new LED C3 tail lights I had bought. Modded original C3 bumpers. C6 cross flags emblem used instead of original 'corvette' lettering. C6 inspired license plate surround, as is the lower modded valance with exhaust cut outs, and reversing lamps. Used the 'corvette' logo found on the C6 rear bumper cover
Much surgery needed to get C3 body to work with the C6 frame. Clearly the most obvious thing is the rear wheel arch which had to be pushed back nearly 7". Uses Z06 rear brake ducts, C6 side marker lamps, 'bullits' behind the seats, plus you can see the paring seams of the tilt front. Sill panels still under design/construction stage.
Every square inch of this body has been modified and is hand made. Trying hard to make it look like a chrome bumper C3, but really nothing is the same. The very front is only 2" wider, but it changes quickly and is 7.5" wider at base of windshield. Modded original front bumper. All grilles custom made, the 2" extra in width is found in the centre grille. Side grilles are standard in length but 2" deeper. Modded original C3 pop up lights to be retained. Car is taking shape npw.
The following 2 users liked this post by aussieross01:
Jstan2014 (02-16-2019), Rescue Rogers (05-06-2023)
Old 02-16-2019, 05:25 AM
  #57
emccomas
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Reminds me of the guy that put 1961/1962 body panels on a 1990-1995 ZR-1. Nice work guys.
aussieross01 (02-17-2019)
To '69 modded vert body on top of C6 Z06 platform
Old 02-16-2019, 04:43 PM
  #58
loup68
loup68's Avatar
I just found this thread, otherwise I would have asked this question sooner. I hope that you somehow treated the aluminum frame to the steel C-3 windshield pillers. Otherwise you will
get the steel eating the aluminum. Did you use some kind of a plastic barrier? Lou.
Old 02-16-2019, 06:59 PM
  #59
aussieross01
If you look earlier in the thread, you'll see where we boxed and plated the original aluminium 'A' pillar of the C6, We then fabricated a plate, and re enforcing system on the widened C3 metal windscreen frame. Then used a special bonding compound to glue and bolt together, so the glue is a barrier. 9 bolts were used each side for securing. We put them all in just past finger tight, waited for the glue to nearly set, then nipped the bolts down. We had to get this process signed off by our certified engineer.
The metal birdcage was also treated to a 2 pack quality sealing undercoat with superior adhesion qualities, so pretty happy with the process this end. Sent a couple of pics
Old 02-16-2019, 07:34 PM
  #60
aussieross01
Quick Reply: '69 modded vert body on top of C6 Z06 platform
