C3 corvette floors get wet
Here is my problem, when it rains the drivers and passenger side floors collect water. I have adjusted the T-tops and windows to the service manual specifications. I actually replaced both floor boards because they had some rust.
The car only sits out when I bring it home {other toys in my garage} and is normally parked in my warehouse when I am not using it.
You don't need the assembly manual though...just a helper with a hose that is willing to spray for you. Don't spray in a stream, try to simulate a heavy rain while driving as your helper sprays the front of the windshield head-on.
I also had leaks from the T-top seals but those came through at the top both through and on the windshield header trim.
The leaks were discovered when I'd driven the car to a card game and there was an unexpected and extremely heavy rain. Fortunately the car seems to have been a garage queen before my ownership and definitely after so rusting was minor and easy to address.
Should windshield removal, rust removal, treating, painting, etc. be necessary pay great heed to warnings about the corner trim that holds the T-top pins. Remove them AFTER removing the windshield and reinstall them BEFORE the windshield or you WILL nick the edge of the windshield on at least one of the four screws in the front of those pieces. Such nick WILL make a running crack!!!
I can honestly say this first Corvette was a POS rust bucket but I learned a lot about Corvette's owning that car for a couple years.
the cure for that was to pull the stainless ALL off including the interior trim.... clean up the steel which was previously painted with w/s outta position, lucky ME.....and so with it all naked, down to the frame and glass still installed, I took many tubes of RTV black to completely fill the open spaces/channels/gaps and then put the stainless over top pieces back, then wrapped with black vinyl glued down good, then put the glass trim back, totally bedded in the RTV did not bother with the retaining clips..
the top gasket seals well to the vinyl...no leaks, the tops of the fenders and the trim is totally filled and sealed to the glass/metal/body...no gaps......over the years, it leaks a bit around the side windows....but that's the lousy new rubber seals, nothing so bad as to get all ape over.....
