speedometer gear diameter
Old Aug 10, 2017 | 12:36 PM
oldrick's Avatar
oldrick
1st Gear
Default speedometer gear diameter
I have a early 1964 Corvette with a Borg-Warner T-10 4 speed. I replaced the speedometer cable and when spinning it with a drill the Speedometer works fine. When placing the bullet with the drive gar in the trans the speedometer doesn't work. Looking in the hole where the bullet and gear go I can see the gear pressed on the trans and it looks fine. Are there different size diameter gears that go in the bullet ?
Old Aug 10, 2017 | 01:47 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
You might want to post this in the C2 section. I know on my 78, the plastic gear in the trans where the "bullet"/cable connect can be different colors. Believe color has to do with the number of teeth which is related to the diff you have installed.
