ac conversion getting 40 degrees at the vent
Old Aug 11, 2017 | 07:16 AM
chrisviktorjakematt's Avatar
chrisviktorjakematt
Default ac conversion getting 40 degrees at the vent
Although it is only 85 out with mild humidity I am very happy so far with my 134a conversion. 40 degrees at the center vent very cool
Old Aug 11, 2017 | 08:39 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I need a jacket to look at that thermometer!
Old Aug 11, 2017 | 09:08 AM
Street Rat's Avatar
Street Rat
Pretty darn awesome when something comes together and works great.
Old Aug 11, 2017 | 09:10 AM
mark79,80's Avatar
mark79,80
Can you list the parts you replaced and the procedure you did in the conversion?
Year of the car?
Old Aug 11, 2017 | 09:23 AM
jlpskydive's Avatar
jlpskydive
Year of the car?
This please ^^^^^^^ I need to do mine as well.
Old Aug 11, 2017 | 11:58 AM
carriljc's Avatar
carriljc
That's just wonderful. My Hot Rod Air will get down there at first, but then it starts warming up. I'm starting to suspect I've introduced moisture into the system and it's freezing up. I've played with adding and removing R-134a but the cycle continues. I'm thinking I have to start fresh, evacuate and recharge, then see how it does..... unless someone has ideas to share???
Old Aug 11, 2017 | 04:31 PM
chrisviktorjakematt
I started out by replacing my compressor which had died. While researching the conversion process I discovered that a parallel flow condenser was recomended for the r134a converted cars to increase the cooling. I found one inexpensively on ebay $64
http://www.ebay.com/itm/A-C-AC-Unive...38.m2548.l4275. I did have to buy and custom bend some aluminum ac tubes from U bend'em on Summit's web site to make the connections from the new condenser to the existing ac hoses. I replaced the original orifice tube with a blue ford orifice tube which is also supposed to work better in our cars with r134a. You will need some r12 to r134a conversion fittings on the schrader valves. They will need to be the ones that are 90 degree adapters to be able to fit the new style manifold hoses to vacuum the system out and recharge it. They are available from napa for about $10 each. (make sure to remove your existing schrader valves before installing them)
You will need to remove the hood to replace the old condenser. Once I had done that I also replaced my radiator (since 90 percent of the labor was done) with a new aluminum champion radiator very little modification needed to install. Lastly I took it to my local shop to pull a vacuum and fill with r134a
I found some great information here http://tech.corvettecentral.com/2008...4-ac-retrofit/
and here as well http://www.ebay.com/itm/A-C-AC-Unive...38.m2548.l4275
good luck
Old Aug 11, 2017 | 05:14 PM
mark79,80's Avatar
mark79,80
good luck
Thanks for the information.
If I understand, you used the factory hoses to the condenser?
Can you post a picture of how the u bend aluminum tubing runs from the condenser to the hoses?
Lastly what type of fittings do you need for the ends of the u bend aluminum for the condenser and the hoses?
Old Aug 11, 2017 | 05:21 PM
chrisviktorjakematt
the fittings come with the lines, You want one with a male fitting on one end and a female on the other and the second line with two female fittings. I doubt that I can get a pic with the hood back on and mounted to the car but I will be happy to take a look tomorrow and see.
Old Aug 11, 2017 | 05:46 PM
kanvasman's Avatar
kanvasman
Chris, thanks for sharing the details. You just saved me some extra work.
Old Aug 11, 2017 | 07:07 PM
ramair_bryan's Avatar
ramair_bryan
Minus 21 F at the vent...........
Old Aug 11, 2017 | 07:25 PM
Tim 1973's Avatar
Tim 1973
WOW, I can just hope my Vintage air system gets the same results once its ready to test!
Tim
Old Aug 12, 2017 | 12:59 PM
chrisviktorjakematt
For everyone following this do not forget to replace the accumulator/receiver dryer unit any time you open the system to air. Mine came as a combo kit from autozone with the compressor. An important part I did not want to leave out.
Old Aug 12, 2017 | 01:03 PM
chrisviktorjakematt
This is the best I could get with the hood on. You can see the one connecting to the manifold hose beside the radiator the best. I made it a gentle U shape to fit. The one down low and beside the condenser is hard to see and with my particular fitment had to be made into almost a pigtail shape to work. I used the handle from a garden shovel to bend it around to get the shape without kinking it.
Old Aug 12, 2017 | 01:08 PM
chrisviktorjakematt
Yes the factory hoses with the u bend em line from the condenser to the hose. I actually replaced the hoses with new ones while doing the project but they were factory hoses. Just be sure if you replace yours to get specific hoses for the l48 or l82 engine they are not compatible for whatever reason.
Old Aug 13, 2017 | 09:04 PM
C3 4ME's Avatar
C3 4ME
And good engine temp too, so looks like you've got this one licked!
Old Apr 21, 2024 | 08:28 AM
Vinny37's Avatar
Vinny37
Default AC 40 degrees
No matter what I have done, I cannot get my AC to come out cold like this. Any suggestions for me with a 1993 corvette base model coupe by chance? I've replaced everything and still nothihng.
Old Apr 21, 2024 | 11:41 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
1) a 93 is a C4
2) ask your question in the correct forum please.
3) closing 7 year old thread.
To ac conversion getting 40 degrees at the vent
