69 Tach?
Old Aug 16, 2017 | 01:02 PM
jboweriii's Avatar
jboweriii
Default 69 Tach?
On the back Tach housing there is a wire ( capacitor or something) with broken tang. Do i need it? If i need it where can i get it? Thanks
Old Aug 16, 2017 | 01:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It's a radio capacitor... you'll be fine... or you could replace it but you'd best have small hands.
Willcox
Old Aug 16, 2017 | 02:37 PM
carriljc's Avatar
carriljc
I got a generic capacitor (condensor) for points distributor for mine and swapped the lead connector so as to use the harness connector.
You can get one for a little over a buck at rock auto.
Old Aug 16, 2017 | 10:06 PM
jboweriii's Avatar
jboweriii
Willcox
Thanks, i'll try to replace it. I cut all my dash lights and put a 5" splice crimped in. It makes life alot easier, i could'nt put all the lights in without them poping off Would it matter with a after market stereo?
Old Aug 17, 2017 | 12:01 PM
carriljc's Avatar
carriljc
Doesn't seem to make much difference on my aftermarket stereo.... but then again I either play the music on my USB or occasionally a CD.
As far as the dash lights, I got tired of those bulbs popping out so I replaced them with LED lighting strips.
see here: https://www.corvetteforum.com/forums...-and-tach.html
Old Aug 18, 2017 | 01:04 PM
jboweriii's Avatar
jboweriii
The LED light stripe is a thought, i think they also make LED light bulb replacement also.
To 69 Tach?
