Help reading block stamp pad please!
Old Aug 31, 2017 | 11:04 PM
SPCL FX's Avatar
SPCL FX
Default Help reading block stamp pad please!
Top of pad has ......
VO33OCLA
Bottem of pad has......
17S followed by the vin number on the dash !
I have no clue what the top letters and numbers are telling me !
If I'm correct the 17S means Jan. 1977 St. Louis?
Thanks in advance! I finally got it where I could see them!
Old Aug 31, 2017 | 11:21 PM
ed427vette's Avatar
ed427vette
The V is the engine plant (not sure which one it is)
The 0330 in March 30th
The CLA is the designation for what the engine horsepower rating and maybe transmission combo. I don't know much about 77's. you can look up the code in a google search along with the V engine plant.
The 17S is as you guessed and should be followed by the six digit sequential build number.
Old Aug 31, 2017 | 11:42 PM
jyounane's Avatar
jyounane
Hi,
V means the Flint Michigan Plant.
CLA is a 350-cid, 180HP 8.5:1 compression with four barrel carb and with Automatic Transmission
Joe
Old Aug 31, 2017 | 11:56 PM
SPCL FX's Avatar
SPCL FX
Ok , so was the engine built before the body ! Just after your post I found out the V is for Flint Mi. Plant and the CLA means 350 cid automatic 8.5 to 1 compression 180 hp ! We will have to fix that
Thank you!
Old Sep 1, 2017 | 12:00 AM
SPCL FX's Avatar
SPCL FX
Originally Posted by jyounane
Hi,
Joe
Thank you Joe
I believe there is something wrong in that equation, a 350 with only a 180 HP just is going to be enough!
Old Sep 1, 2017 | 06:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SPCL FX
...so was the engine built before the body...
Always. Every part on your car would have been manufactured, shipped to St. Louis, and stored before assembly of your car began.
To Help reading block stamp pad please!
