A/C Help
Old Sep 3, 2017 | 12:11 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Default A/C Help
What could make the A/C come on when the switch is off on my75?
Thanks for any help you can give.
Bob
Old Sep 3, 2017 | 12:34 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I would suspect the rotary switch in the console.
Old Sep 3, 2017 | 01:02 PM
Pa'svette's Avatar
Pa'svette
Thanks, I thought the rotary switch just controlled the vacuum.
Old Sep 3, 2017 | 02:03 PM
ntfday's Avatar
ntfday
My 76 should be similar to your 75 and IIRC there's an electrical switch on the front end of the rotary switch. You could also have a problem at the AC relay or the pressure switch.
Old Sep 3, 2017 | 03:00 PM
henrikse's Avatar
henrikse
My 73 was on all the time and I found the compressor micro switch down by the rotary switch was made all the time. (there are two switches here)
To A/C Help
