78 C3 A/C clutch screamming
When it is cool in AM clutch kicks in and out great. Drive it in PM when temp 100 deg. it will not engage, just screams, major slippage.?????
I know thing expand but for a clutch not to engage???
Any one have similar experience.??
It's a new system.
I know I have to change out the clutch on the A/C.
DB
It's a new system.
DB
In the morning when it's cool, the pressures are lower than when it's 100 deg out. Is the belt in good shape and adjusted correctly? Also has there been work on the ac lately, possibly an overcharge? do you have AC gauges you can hook up and wee what;s going on?
Started up car this afternoon. turned on switch. went to connect elect. lead to comp. clutch starts to spin as normal no noise, then it starts to screech and then spin then screech and then spin off and on then screech. clutch turns as it screeches.
Over charge?????
SO I gather it may not be a magnetic clutch but pressure in system? causing the pump not to turn>????
DB
If it is not pumping and engaging then there is no way check what it is doing other than to check the current pressure in the line. which will reflect the out side temp. yes?
If I hook up the gage and all I get screech, then I can not get a read???
bad pump.
Upon reflection on my install, flushing the parts, and installing the A/C comp. and 134a with out vacuuming it first may be my problem. Could be there is something that I did not get out that causing the pump to stick. If there is no other reason for the clutch to screech as it spins. then there is something in there. I'LL have to get a new pump.
Having a little moisture and air due to not vacuuming shouldn't cause the compressor to fail(although it will certainly effect the cooling ability). Debris from a previous failure or a defective rebuilt compressor is more likely. Try turning the compressor clutch by hand, if you end up changing it, be sure to replace the dryer and flush the system.
I will check temp and pressure then recharge system and see what happens.
Does refrigerant have an odder like gas and other fluids have????
Attached gages this am opened all valves ..76 outside temp..low side reads 95 high side reads 95
started motor, run at 1,000 rpm, reach temp of 195-200, as soon as I connect electrical connection to clutch it screeches.
gages...low reading 350 + high 130
THIS WOULD indicate a blockage?? on low side???? orifice tube???? or where???
Possibly clogged accumulator or bad check valve on low side in compressor. Check valve not allowing refrigerant to pass.
Clutch never really kicks in or spins freely (Normal) just screeches.
After several hr's of rest both read 110
Does not matter at this point, will pick up new pump today and a vac pump......
After removing the A/C pump, I took out the Orifice tube.
This is what I found....NOW I know I cleaned that out. it smells like burnt oil, there is fiber of some sort and metal flakes.
You need to disassemble as much of the system as possible and clean/flush all the debris out or you will end up with the same problems. Replace the dryer, vacuum for at least 30 minutes, preferably 1 hr, then add oil and refrigerant. When you vacuum it, the vacuum pump needs to run for the whole time so that as the moisture boils it can be exhausted out through the pump.
Yep....will go as far as possible today...nephew comes over tomorrow he can help remove hood......
