Frame check versus front bushings
Old Sep 9, 2017 | 10:02 AM
Dbrummy1@yahoo.com's Avatar
Dbrummy1@yahoo.com
Default Frame check versus front bushings
My '75 pulls slightly to right, during braking, coasting or acceleration. My question is where to start troubleshooting. I have recently had the tires balanced. Do I need to check the frame first or replace the frt end bushings and get it aligned? I don't know if it had been in any accidents or not.
Old Sep 9, 2017 | 10:35 AM
cagotzmann's Avatar
cagotzmann
Make sure your tire pressure is equal in all tires to start with. Measure tread depth for consistent wear on all tires.
Look at your tire wear pattern. Are the tires wearing evenly inside vs outside. If not you have an alignment problem or steering with worn parts problem.
check the complete steering parts for play.
Tie rods, ball joints , wheel bearings , suspension bushings etc.
Then check brake pads (dry no fluid leaks) / calipers for leaks / rotor for unusual wear.
If the steering suspension checks out, alignment can be verified by tire wear and does it drive nice and straight with very little steering adjustments on nice flat road.
If both check out then it could be a brake pad \rotor or air in the caliper problem on one side. (bleed to fix / check)
Old Sep 9, 2017 | 10:55 AM
BBCorv70's Avatar
BBCorv70
My 70 used to pull to the right. Had it aligned a few times, nothing seemed to help. Some time later, when I replaced my tires, problem went away.
I think what happened was I rebuilt the front end, drove it a while before getting around to having it aligned. Doing so may have caused a belt shift?
Some suggested swapping left - right wheels, see if the direction of pull changes. I can't say whether this would work, never tried it.
Old Sep 9, 2017 | 11:41 AM
joewill's Avatar
joewill
does it pull the same during braking or the same all 3? braking/coasting /acceleration?
Old Sep 9, 2017 | 12:50 PM
Dbrummy1@yahoo.com
Yes slight drift
Old Sep 9, 2017 | 12:52 PM
Dbrummy1@yahoo.com
Worth a shot. Cheap and easy to check it
Old Sep 9, 2017 | 01:03 PM
Dbrummy1@yahoo.com
Recently did brake hose replacement. Didn't see any leaks or strange pad/rotor wear.
Nothing seemed loose but all frt end seems to be original so there is that chance the bushings are causing it. Just don't want to rebuild frt end and ruin new parts if thoughts was frame issue!
To Frame check versus front bushings
