Changing hinge pillar possible?
Old Sep 10, 2017 | 07:35 PM
Guildgun6's Avatar
Guildgun6
3rd Gear
Default Changing hinge pillar possible?
I am working on a 69' corvette that has been over customized. I want to put a replacement body that I bought on the old frame but I want to use the original VIN because all numbers match. Is it possible to change the left side hinge pillar with the VIN to the other car I'm restoring? All original fiberglass has been over customized. Any advice? Can this be done?
Old Sep 11, 2017 | 02:34 PM
Greg's Avatar
Greg
Just another Corvette guy
Yes, but I probably wouldn't broadcast that info.
Old Sep 12, 2017 | 02:58 AM
terrys6t8roadster's Avatar
terrys6t8roadster
The tag on the hinge pillar is the trim tag, on my 69 it is fastened with pop rivets. Which can be easily drilled out. The vin tag is on the driver side windshield post and should match the your title. T
To Changing hinge pillar possible?
