break fluid death?
Old Nov 14, 2021 | 01:43 PM
bluthundr's Avatar
bluthundr
The Motive Bleeder is touted all over the forum, but I've never had a problem bleeding my brakes the normal way.
Old Nov 14, 2021 | 08:22 PM
ebbnflow's Avatar
ebbnflow
When your pals confirm your old fluid is no good; ask them if you might wash their newest vehicles with it.
Result should either confirm or deny their assertions.
Old Nov 14, 2021 | 08:28 PM
ebbnflow's Avatar
ebbnflow
Originally Posted by c6_racer_x
in my experience, fresh fluid gives a firmer pedal feel than older fluid.
99% of the "improvement" that most people notice when they switch to "braided stainless" brake lines is from the fluid flush that happens when they replace all 4 flexible brake lines.
I'm not saying you'd notice the degradation over the years, it happens so slowly and gradually, but if you flush and refresh the brakes with fresh fluid, you'll definitely notice an improvement all at once.
^^^^this^^^^
Old Nov 14, 2021 | 10:30 PM
interpon's Avatar
interpon
Pretty sure sealed tight will last several years..to op…
and…
Old Nov 15, 2021 | 05:24 AM
Mr D.'s Avatar
Mr D.
It's been 4 years wonder how that bottle of brake fluid is holding up.
Old Nov 15, 2021 | 01:49 PM
Mark G's Avatar
Mark G
It gets dark as it absorbs moisture.
Simple test: New = clear as gin. Old will be the color of a medium beer.
If it's a little less than clear I'd still use it if I was in a pinch. Brake fluid is cheap..
Old Nov 15, 2021 | 02:59 PM
L-46man's Avatar
L-46man
Okay...even though this is a 5 year old thread...
You all seem to think that the 'issue' is whether the lid is screwed on tight....that is only ONE PART of this.
Polyethylene Bottles are made from the cheapest recycled plastic. Polyethylene is THE BOTTOM of the list of 'noble plastics'.
You all seem to think that PE is impervious to weeping in water vapor...IT'S NOT. Gradually, the bottle will absorb water vapor.
I went into the garage the other day to grab some pretty expensive rubbing compound. It was in a PE bottle. It was DRYED OUT SOLID. It 'wept the other way...out!
I would say that sub-one year, you're okay...after that CHUCK the DOT 3/4
Brake fluid is HYDROPHYLLIC...it absorbs water from air, RIGHT THROUGH THE BOTTLE!
If you REALLY want your brake fluid to last....put it in a glass bottle with a really good lid/cap.
Cheers Unkhal
Old Nov 16, 2021 | 12:30 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Cheers Unkhal
Absolutely correct on the PE allowing water molecules to pass through. I've heard/read that 6 months is the limit for an opened container - . Besides, if you need to top off within 6 months, you've got bigger issues than questionable fluid.
This may seem over the top, but maybe dropping a new clean steel nail when capping an opened container could be the litmus test for a DOT 3 or 4 fluid's viability. When you want to use the fluid to top off, if the nail has any rust appearing on it the fluid is past its water absorbing limit. Really, this conversation borders on penny wise and pound foolish.
Old Nov 19, 2021 | 05:12 PM
Cooter Tech's Avatar
Cooter Tech
Originally Posted by Mr D.
Wow how did we ever survive the 70's.
My thoughts too and I go back to the 60s.
Old Nov 19, 2021 | 11:34 PM
Mark G's Avatar
Mark G
A couple yrs ago I bought a few brand new smaller bottles of brake fluid. Got home, opened them up. One of them the fluid was really dark just from sitting on the store shelf/warehouse, etc. It had absorbed moisture and was no good. The others were just fine, clear as water. It's possible the seal was not sealed, who knows? The store wouldn't take it back ...lol....
Old Nov 20, 2021 | 06:07 AM
Chuck72's Avatar
Chuck72
Years ago, brake fluid was sold in a metal can, topped w/a metal screw-on lid which contained a foil/cardboard lid insert.
Old Nov 20, 2021 | 09:30 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Cheers Unkhal
Which brings up a good point....don't buy any more than you really need, no matter how good the "sale price" might be.
Indeed..........
Old Nov 20, 2021 | 11:06 AM
  #33
Mark G's Avatar
Mark G
On a counter-note, I have a brake exchange/bleeding machine which has a large 2-gal (new fluid) reservoir where there is still about a pint at the bottom of the reservoir even when it's 'empty' that you can't really get out (one of my peeves).
One would think it would absorb moisture real quick and discolor. What's astonished me is how long the remaining brake fluid will go and NOT not become discolored ...even after a few months of no use. I had expected it to spoil fairly quick, and yellow/brown -- it hasn't. Obviously how long it'll takes depends on one's ambient humidity conditions and other factors. Anyway, just thought I'd share that....
