More gauges - Column dual gauge holder
Needed to add a trans temp gauge as well as second tachometer (OEM is reading high and I'm not going to be taking the dash out to fix till next summer). My solution was to add them to the column. I put the trans on the left which partially covers the speedo but only from 125MPH and on. The tachometer is positioned to fit in the center of the current tach allowing me to still see the OEM as well as the turn signal. I used a bosch 2 5/8". The trans is a 2". It looks a little like a Mickey Mouse headset but works really nice. It is held on with a zip tie around the column, with a groove made into the 3D print to keep the zip tie from moving as well a notch printed in that grips the little bump out on the left side - also helps hold it in place. Printed with ASB plastic because of summer temps.
