engine decode help
Old Sep 25, 2017 | 10:06 AM
2airtime2's Avatar
2airtime2
Default engine decode help
On the pad on the front passenger side of the engine is has
K0911TBD a 350 made in Canada on 9/11
under that code it has 1104811...it's possible that the 1st digit is a T instead of a 1
what does 1104811 mean?
Someone put this engine in because it's a California car which came with a 305.
Old Sep 25, 2017 | 10:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 2airtime2
...K0911TBD...what does 1104811 mean?...
TBD indicates a 350 CID truck engine used in 70 and 71 and again in 79. 1104811 is probably a VIN derivative for the original vehicle the engine was installed in.
Old Sep 25, 2017 | 11:21 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
This should make it easier
http://www.mortec.com/
http://www.nastyz28.com/sbchevy/sblock.html
http://outintheshop.com/faq/casting/castings2.html
http://www.nastyz28.com/chevy-engine-code-stampings.php
To engine decode help
