Could be true. His car may have had iron, but it came from St. Louis with aluminum.
Hope, he insisted his came factory that way,
You know being into vettes as you are there are people who believe their own opinions as indisputable facts and nothing will ever prove them wrong or mistaken.
Anyone know the difference and will they interchange ?
It is possible to swap the older iron diffs into the 80-82 cars. There are quite a few other parts that need to be changed as well. (half shafts spindle flanges, strut rods, strut rod bracket, drive shaft, Not sure if I've missed anything)
Although there were quite a number of parts designed for the 1980 Corvette that found their way into the last several thousand '79 cars, I've never read any suggestion that the aluminum Dana differential was one of those items.
