1st C3 and already having brake issues
I bought my 1st C3 last week and drove it 3 times since. Today I started the drive it and the brakes gave out on suddenly( luckily right before I hit highway). The car use to be belong to my father in law and he changed the brake master cylinder, metal brake lines, calipers and rotors last year.
Any suggestion on what could make the brake system loose all pressure?
My father in law had it sitting for about 8 months. But I drove it a few times last week and earlier this week. Ill bleed it over the weekend and hopefully that solves the problem.
Without a loss of brake fluid, and assuming pedal goes to floor, I would be looking at the master cylinder, or power brake booster (if of course it has power brakes).
I saw a booster filter online. if vacuum line that filter is off or loose, could that also be a reason for no brake pressure?
thank you
If you were able to stop the car just with hard pedal could point to booster or vacuum issue with it. If pedal went to floor easily there is a leak or master went bad.
Bleeding isn't going to fix it as air doesn't "appear" without a leak. You need to do a detailed inspection before just throwing parts at it.
make sure it's the booster before you change it. You don't want to do that job for nothing. Start with the master.
Is the brake system from the 79 or the 94? What all was reused from the 94 model ?
Is the motor modified from stock? Make sure if it is that it makes enough vacuum to work the 79 system brakes. You may have to go to a different system.
Be smart and don't start throwing parts at it. Troubleshoot/inspect the system to know what you really need, any local parts store will carry any part you need.
FYI, a power brake booster will not cause loss of braking that is a function of the master cylinder and calipers.
What thread are you reading that mentions a 94 ? I assumed the OP, C3LT1, has a 70 to 72 LT1.
thanks for the clarification, important to know the year and all modifications if the correct answers are expected.
BTW.....welcome to the club. They ALL need their brakes, calipers and seals replaced at some point. Its just how these particular cars age.
I replace that pin with a better one and now brakes working again.
Thanks to everyone for the help. I am glad I found this forum!
Where did the retaining clip go? Without that pin, you lose a LOT of pedal travel- And looking at the end of that pin, I think looking for a new one would be a good thing. And more than likely, the brake lights are on all the time.
