Do you foot the bill when . . . . .
Old Oct 25, 2017 | 11:52 PM
Z06LMB's Avatar
Z06LMB
Default Do you foot the bill when . . . . .
As the customer do you expect to pay for parts broken by the shop? Do you expect to pay for the time it takes to re-do a mechanic’s screw-ups?
If you shopped around for a shop to do your work, was it any concern how they charged for their work? By the job, by the hr.?
Old Oct 26, 2017 | 12:46 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
It all depends on the situation.
You don't explain what he screwed up and what he's charging you for it. Providing more information will get you a more accurate answer.
For example.... If they're changing the water pump and a wrench happens to hit the radiator and put a hole in it than its the mechanics fault and should be his responsibility.
But if he's changing the water pump and a bolt happens to snap inside the engine block then that's not his fault and that expense would be passed onto the consumer.
Old Oct 26, 2017 | 02:27 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Good points.
Old Oct 26, 2017 | 07:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is your question in general or do you have a specific instance in mind?
Old Oct 26, 2017 | 07:57 AM
oldgto's Avatar
oldgto
Agree with Douglas.... more info needed.
Old Oct 26, 2017 | 08:26 AM
RMVette's Avatar
RMVette
Old Oct 26, 2017 | 08:31 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Its like when your getting a massage and the masseuse slips and she.........oops, wrong forum. YA the broken bolt analogy, ya thats a good one, go with that
Old Oct 26, 2017 | 06:33 PM
The13Bats's Avatar
The13Bats
Im very jaded on this subject ,
But no, i wouldnt pay for a techs ***** ups,
i have in many ways many times,
You would think i would learn not to be so trusting,,
Old Oct 26, 2017 | 08:17 PM
ignatz's Avatar
ignatz
I think you don't go into a shop with a big job cold. You find some possibilities and have them do relatively harmless this and that to get a feel for their work ethic. Decide if they are really car guys or not. You have to talk to people, know their names. I learned this from my father. If they are all business and wearing uniforms, I would move on. I realize that is a little fuzzy, but I have a pretty good feel for the local shops and where I would go for what, and whom I can have an honest discussion with about unforeseen circumstances.
An example I have in my experience was a gas station I frequented where I came to trust the owner. And probably he came to expect my repeat business. My car was up on a lift, the mechanic opened the door with the frame sagging and chipped the edge of the B-pillar. He called me up, told me what happened and said my car would be a little late because he was sending it out to a paint shop to fix the damage. That is not my only example.
Those pre-requisites being in place, I would not expect to pay for a screw up without a really good reason.
If you're inner alarm bells are going off, probably time to move on.
Old Oct 26, 2017 | 11:19 PM
vbgod1's Avatar
vbgod1
Need more info, but I see a difference between a screwup, and for want of a better term, "chit happens".
Broken bolt, r&r a radiator and a seam starts leaking, anything fitting "Geeze, it's 40 years old" it comes with owning an old car, no matter who works on it. Stupidity, like poking a hole in the radiator, leaving trailing arm shims out or overheating for a loose clamp, that should be on them.
To Do you foot the bill when . . . . .
