1971 L-88 engine ?
Old Oct 31, 2017 | 07:28 PM
Gold Dragon's Avatar
Gold Dragon
Default 1971 L-88 engine ?
http://seattle.craigslist.org/see/pt...361011949.html
Found this on CL today. Something smells fishy. I thought 1969 was the last year you could buy an L-88 equipped Vette.
Old Oct 31, 2017 | 07:58 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Seattle is a mighty fishy town! L88 crate engines were available over the counter. Who says this one is from a Corvette? The ad says it has a Corvette tripower setup on it. Sounds like a mutt...can hardly tell what it is.
Old Oct 31, 2017 | 11:14 PM
TimAT's Avatar
TimAT
That smells so bad you need to hold your nose. Without casting numbers, block stamps, and looking at the lower end, it's a guess. IT could have come from a 1970 pickup someone slapped a tri-power on it (for the cost of that alone is up there). And for $6k? The intake and carbs are worth almost that much alone- Maybe more if it's a date coded matching carb piece that someone needs to complete their resto.
Old Nov 1, 2017 | 10:23 AM
3X2's Avatar
3X2
And it's a 67 intake.
Old Nov 1, 2017 | 10:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
another spraybombed "low mi" boat anchor
Old Nov 1, 2017 | 11:08 AM
Kevova's Avatar
Kevova
Bring your casting number guide with you. Still no guarantee it's actually 1 engine and not pieced together. There were more engines sold than cars built with them. With the crate engines available now, I'm not sure it's worth 6k. For a 70 + the LS7 verifiable crate engine would be the "****".
Old Nov 1, 2017 | 06:03 PM
derekderek's Avatar
derekderek
it is definitely an orig L88. you can tell by the grey paint on the engine and the black paint on the valve covers...
Old Nov 1, 2017 | 11:24 PM
Priya's Avatar
Priya
Good to know, now I won't be fooled if I every come across one.
Old Nov 2, 2017 | 07:09 AM
rick1025's Avatar
rick1025
Cant be sure from the photo,but it looks like an oval port manifold;400HP.
Old Nov 2, 2017 | 09:39 PM
2MQ's Avatar
2MQ
Iron heads.
Old Nov 3, 2017 | 03:21 PM
Mark_Milner's Avatar
Mark_Milner
Well, it looks like a 4-bolt main block from the two oil ports over the oil filter. The heads are most likely oval port iron heads with an oval port tripower manifold (400 hp). I'm not sure what the value is on the tripower these days but they got up to about $4000 and more for awhile. Still, the engine is a mutt. Venture very carefully. At best, it is a high compression 4-bolt main with oval port heads (only installed on 2-bolt main engines) with a very wrong intake and carb setup.
To 1971 L-88 engine ?
