Help! 78 Vette Engine issue
Old Nov 8, 2017 | 11:42 PM
hpxt's Avatar
hpxt
I’d cut my losses and have another shop look at it. Do you have a Corvette club in your area? They can recommend a shop, or better yet have one of the guys take a look.
Hard to tell from the video, but if it’s rod knock you’ll need to pull the motor. I also have a 78, l48 and installed an Edebrock top end kit. I hammered it (as derekderek mentioned) and on the third run spun a rod bearing and ended up pulling the motor.
Good luck on resolving this.
Old Nov 9, 2017 | 06:25 AM
derekderek's Avatar
derekderek
Seeing this a lot of boats. Guy has it treats it pretty gentle 3500 RPM all the time. New guy buys it. Full Throttle 5,000 RPM. Engine Pops in less than a week. Complains that the guy sold him a boat with a bad engine. You want to drive it like a dragster? You need a new crankshaft in it-good bearings with correct clearances anyway. A tired engine with .005 or more will stay alive as a commuter-grocery-getter.
Old Nov 9, 2017 | 12:10 PM
78stan's Avatar
78stan
Rod knock. Bad rod knock. They took that car and hammered the stuffins out of it. And they will say "Wasn't me!" And you will have no way to prove anything or get a nickel from them. Did you pay with credit card? If so, at least you can get that back...maybe.
Rod Knock!
That could be associated with running the car while lean?
You might have something there.
Old Nov 9, 2017 | 12:34 PM
bradleyb66's Avatar
bradleyb66
Yeah, after listening to your video, I wouldn't describe that as a 'popping' sound. It does sound more like something worse. To find a reputable shop in the Temecula area, I would start another thread with something to that effect in the title (not everybody here reads every single thread).
Old Nov 9, 2017 | 12:45 PM
78stan's Avatar
78stan
Thanks Bradleyb6.
The shop overhauled my carburetor, gave me my car back with it running lean. Drove it back to the shop three times and this is what I get.
Old Nov 13, 2017 | 03:04 PM
78stan's Avatar
78stan
UPDATE: I had my insurance send over a master technician to surmise what the hell happened. The tech came to my residence, and started looking at everything he could. He noted the carburetor was not adjusted properly (in fact it was running rich). He als noted the service to the carburetor was not complete and there were some linkage and valve issues... he tugged on the carburetor valve and I was leaking fuel (engine was off).
Furthermore, he hear an issue with the lifter on the engine over valve 6 and/or 7. Did a compression test with an old type of machine and found out the engine is failing the compression test. His diagnosis and the discover of blue and black smoke tends to think the engine is dying on its own due to age.
So... I need a new engine! This was the original 350 small block for my 78 vette and it was just its time. I found it all too convenient that it dies right after a visit from the corvette shop... but there you go.
Old Nov 13, 2017 | 03:11 PM
Aerovette's Avatar
Aerovette
It almost sounds like the flex fan hitting something when it revs high. Mind you, video has no "direction" for the sound source, but it doesn't sound like a cam issue to me.
Old Nov 13, 2017 | 06:43 PM
78stan's Avatar
78stan
Well after the Corvette Shop tuned the carb again... which is now running rich by the way... that high pitch sound and rattle is gone.
My insurance sent over a master tech today and he took a look at the engine. He says it is an issue with the engine due to old age and that it fails the compression test.
Old Nov 29, 2017 | 04:44 PM
78stan's Avatar
78stan
I found out why the vehicle is running rich... it disguises the popping. I believe my Holley carb has a power valve issue. Could this popping sound be the result of a power valve blowout?
I reviewed my invoice of what the insurance paid for repairs, and this shop charged over $600 to overhaul my Holley Carb... that is robbery! Anyway... the engine has issues now because of the can running lean... piston rings damaged and oil leaking through valve guides causing me to blow white smoke. Anyone know of a Corvette Shop in Temecula or what steps I can take to get my money back on this carb?
