((( testing a radio )))
Old Nov 10, 2017 | 08:32 PM
Bills17n72's Avatar
Bills17n72
Default ((( testing a radio )))
hello friends is there a way to test a radio out of a corvette to see if it works? thanks Bill
Old Nov 10, 2017 | 08:38 PM
Wee's Avatar
Wee
Depends on year.....My 72 has what looks like an amp that has to be hooked up as well.....Other than that just hook it to a 12 volt battery and some speakers.....The early units used 10 ohm speakers.
Brian
Old Nov 10, 2017 | 08:41 PM
Bills17n72's Avatar
Bills17n72
its out of a 77
Old Nov 10, 2017 | 08:43 PM
Wee's Avatar
Wee
I'm not sure if your unit would need the external amp thing or not....I know at some point they were built into the radio.
Brian
Old Nov 11, 2017 | 12:07 AM
henrikse's Avatar
henrikse
Sure. Here is diagram off 1973 but may be the same. Put speakers on bench and battery to test
File Type: pdf
Old Nov 11, 2017 | 06:11 AM
2airtime2's Avatar
2airtime2
Of course there is. I used to own a consumer electronics store. Part of the business was car audio (& CB radios, [just dated myself ]. We had a bench power supply but a battery will work just fine. You need some knowledge to do it. You need to know which wires to hook to what.
Ground can generally (but not always) be hooked to the metal case. Power is generally a larger red wire. Speakers or preamp out put can be any color. Post which radio we are talking about and pictures if possible. Someone here knows.
To ((( testing a radio )))
