Seat question
Just checking in with this group to see what you say.
Thank you.
David Howard
AllVettes4Me
The only exception is on the 1970-1975 seat backs with shoulder harness. The seat frames had a set of holes in them and a different upper bracket which makes it pretty much impossible to convert a standard set of frames to a shoulder harness set of frames without this extra bracket and holes. I can do it.. but time is money.
So, lets just say it's cheaper on the customer for us to purchase a used shoulder harness back than it is to try to convert one that didn't have this option.... I just ran into this in my shop last week.
All the frames have the holes in them for the seat back molding, (there are three) from 1970-1978... it's those rectangular extra holes for the belts to pass through as well as the additional brackets that screwed into the seat back that make the difference. If needed I should have some pictures somewhere.
1970-1978, the biggest difference is the adjusters and adjuster brackets which varied. I'd have to research this to know for sure what years fit what... I don't remember off the top of my head. Some adjusters had flat rods, some had round... flat tended to be the 1970-1975 style, round 76-78... But the brackets are the one key to knowing if the seat will actually fit the car.
There are a few other slight differences in the lower frames but nothing that wouldn't allow you to install any 70-78 cover on them.
Ernie
1970-1978, the biggest difference is the adjusters and adjuster brackets which varied. I'd have to research this to know for sure what years fit what... I don't remember off the top of my head. There are a few other slight differences in the lower frames but nothing that wouldn't allow you to install any 70-78 cover on them.
Ernie
David
Just message me at service@willcoxcorvette.com i will.
E
The seat adjuster rear brackets were different, here are the different years.
68-72
73-74
75-78
