EVERYTHING NEED TO WORK : Interior courtesy light
Old Nov 15, 2017 | 05:56 PM
ricks_road54's Avatar
ricks_road54
Default EVERY THING NEED TO WORK : Tomorrow Interior courtesy light
Hi,
I need to have all my courtesy light works, i think that you can see in tris picture on of them?
Right?
Where this bulb go?
And why the rear Bulb (behind the seats) is ON every time?
The door contact will have a problem? How can i check them? i didn't see any wire?
Could you tell me wich color have the wire of the courtesy light on the passenger side?
Old Nov 16, 2017 | 12:14 AM
henrikse's Avatar
henrikse
The wires are orange to the courtesy lamps Other wire is white. Orange is positive and ground is white. Ground comes thru the courtesy lamp switches. Front of door. If you take kick panel off you can see the 2 white wires going to switch. You can use a meter to check. Should have ground when door open and not when door closed. The drivers side courtesy lamp mounts to the left of the cover you have off. The odometer zero **** is hanging there. It goes into bracket along with vacum light overide switch. In that bracket is a round hole to put the lamp socket in
Old Nov 16, 2017 | 02:31 AM
Greg's Avatar
Greg
Just another Corvette guy
The socket hanging down looks like an instrument light bulb socket.
Old Nov 16, 2017 | 07:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: the assembly instruction manual (AIM) would be helpful to you for getting your car back together.
Old Nov 16, 2017 | 07:24 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
GREG dash light ctr console maybe .
Old Nov 16, 2017 | 01:14 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
A few suggestions:
1. Always state the year of your vette
2. Invest in a AIM, Assembly Instruction Manual. Like Easy Mike suggested.
3. Invest in the GM service manual.
Old Nov 17, 2017 | 02:17 PM
mobird's Avatar
mobird
If you're trying to say that the interior lights stay on when you have the door shuts for a while, check your courtesy light timer (orange box under the passenger side glove box area). If you connect the two white wires, they should only come on when the door is open.
Old Nov 17, 2017 | 07:15 PM
ricks_road54
I confirm, it's one of them odometer lamp missing (bottom left, i think a full pain to plug it again)
Old Nov 17, 2017 | 07:25 PM
ricks_road54
I made some test :
On LH courtesy switch : 2 wires - one black "ground" and one other that go ...
Can't find LH lamp bulb and support
On RH Courtesy switch one white wire (gournd) that go to ...
On RH lamp bulb, two wire, one orange and another white that go to...
I think that all the wire go to the same in law.
The RH Courtesy lamp and back courtesy lamp (LH is not here) can be swtich off if i turn the headlamp switch to lower the luminosity of the dashboard. Theses lamp is ON only when the luminosity switch is full UP. (sorry for my english). I don't know if this scenario is normal?
To EVERYTHING NEED TO WORK : Interior courtesy light
