Holiday Pay It Forward 2017
#41
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Rescue Rogers (11-25-2017)
#42
Senior Member
St. Jude Donor '10
David about to PM you regarding those wheel trim pieces if they are still a available.
Thanks iIke[/QUOTE]
I just need a good address PM'd to me and I will send them out to you today.
Thank you and best regards,
David
Thanks iIke[/QUOTE]
David
general ike (11-29-2017)
AllC34Me (11-26-2017)
#44
Senior Member
St. Jude Donor '10
Big Block Chromed Steel Valve Covers
Claimed by CHAMPS65; thank you Joe.
I cannot use them but if you are participating in the Pay It Forward and you can use them let me know.
Best regards,
David Howard
AllVettes4Me
Best regards,
David Howard
AllVettes4Me
#45
I have a front end bra that is up for grabs....I'll take pics today. Shipping included to the lower 48. I'm going to see if I can dig up anything else.
Brian
Brian
#47
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Thank you David PMed you about the tire trim!!!!
To add to the list some touch up paint from Color and Drive. It for a 1972 Ontario Orange. My car had been repainted so it quite did not match up for my liking and so I went to a local paint store and matched it. The kit is basically unused. Let me know if it can help anyone. Ike
#48
A couple of items to add. More will follow.
The first is a new set of points. I was told that they were for my SB 73 but please verify if you'd like them.
The second is a stock automatic shifter **** and button from my 73.
#50
I have a pair of used 68 door skins available to anyone who can use them. One has light damage in the form of a crack near the handle area, not bad. Due to size, pick up only please or I can meet you within 75 miles of 14891.
#51
and another...
81 CCM, no idea of condition, car ran on this when I bought it but I had carb problems so I removed the CCM and carbutetor.. has a certified rebuilt by GM sticker.
#52
Tail light lenses out of my '80
The other two housings came with some other parts. Not sure what year they fit. One is missing a mounting stud.
Adjustable strut rods. Bushing on one end is shot. Would be good to rebuild or use heim ends.
Rear shock mounts. Splines seem good, they worked when I had them installed.
Attachment 48228793
[/ATTACH]
Attachment 48228793
[/ATTACH]
#54
St. Jude Donor '17, '19
Wiper Fluid Reservior
Hey,
I have the following wiper fluid reservoir. I think it goes to a 70ish corvette.
Let me know if you have any questions.
God Bless.
God Bless.
#55
Factory strut rods, needs bushings.
Two spring mount bolts.
Two trailing arm bolts
Strut rod mount with eccentrics.
Spring plate
Two e-brake frame mount brackets.
Bare trailing arm R/S.
Some e-brake hardware.
Heat shield under rear diff.
Two brake pad caliper pins.
E-brake cables, work free, with frame brackets.
Batwing for an 80-82.
Two halfshafts. Ujoints are ok, wouldn't hurt to replace them.
Spring plate
#57
Red Road Warrior
St. Jude Donor '10-'11, '15, '19
I've got a wiper bezel for a 73' to ? non AC car. I can't use it, but I did refinish it and it looks great. I'd love for it to find a new home. It's also posted in the 'for sale' section but I'll mark the cost with a link to this thread. I'll have a few more things hopefully. I had a lot of fun doing this last year!
Thanks,
John
#58
Hmm, looking back at that pic, they do look awful black. They really aren't. Have to see if I can get a better shot tomorrow.
#60
I also have a box of small brake parts. I am not sure what these are actually. They were given to me because I "own a corvette". lol. It was told it was old brake parts from a restore job on a 70s Corvette.
