1969 BELTS/PULLEYS for Small Block
I have a 1969 Corvette with the 350/350 restored to factory stock. Power steering with NO A/C. I do not have the smog pump installed. I am looking to purchase belts but the belts in catalogs seem way too long for this application. The only thing I can think is my water pump pulleys are the wrong size. What is the stock size of that pulley? I appreciate any help and info. Thanks!
You may find that your current set up mimics the 1970 L-46.
A 1970 L-46(350/350) which didn't have an A.I.R. pump has the forward belt (crank, water pump, ps pump) and the aft belt (crank, water pump, alt.).
I found the routing in my 69 assembly manual. Looks like with the L46 with PS and no AC both belts go over the crank and water pump. Just not sure about the pulley sizes.
