Hi, I have 1973 L-82 with Muncie gear box. It came from the factory with what must be intended to correct the speedometer. It has the part number 1565211 stamped on it and there is a small nylon part I think it is called a key, part number 6476970. Does anyone manufacture a reproduction? Is there a speedometer gear that I can use and eliminate this altogether? Tried to upload photos no luck will try again later
Thanks!
Hi, I have 1973 L-82 with Muncie gear box. It came from the factory with an "adapter" that must be intended to correct the speedometer. It has the part number 1565211 stamped on it and there is a small nylon part I think it is called a key, part number 6476970. Does anyone manufacture a reproduction? Is there a speedometer gear that I can use and eliminate this altogether? Tried to upload photos no luck will try again later
Thanks!
I just wanted to let you all know I located the issue. The "key" was not inserted into the "adapter" completely so the speedo cable would not turn. Just checked the car and all seems well but I am still interested in locating both Part 1565211 and 5476970. "just in case"
Thanks again
