What is this part called and does someone make it.
I dont know if that starter solenoid I sent ya helped, but these 2 should do the trick. Its the Christmas season, just pm me an address and I will get them out for you in tomorrows mail.
John
Replaced T-tops due to flying rock damage
Double lined interior with dynamat.
New seats
New radio and speakers
New driver window motor
New motor
New radiator
New alternator
New master cylinder
New transmission
New differential
New trailing arm assemblies
New borla mufflers from an 84 adapted to an 82
New catalytic converter
New jigh torque starter motor
New magnacor wires, iridium plugs
New sensors all around
Port matched intake
New injectors with tbi spacers and tower spacers
New tbs
New MAF sensor
New fan blade
New aluminum radiator
New headlight actuators
New horns
New a/c compressor, 134a
New drier and pressure switch
Removed smog equipment
New brake calipers
New control arms
New power steering valve
New pitman arm
New shocks
New O2 sensor
Modified air cleaner setup.
Replaced distributor electronics.
No, I don't work on a corvette.
You have just been disqualified as a legitimate poster. Or is it poser?
Just proving his condescending post wrong.
Francis.
Then, the other poser made an insulting post.
This is NOT CFOT where the children reign without boundaries.
Admit the posters here are newbies and still are learning.
But to be clear, I know my Corvette down to the screws, which I have replaced, fuses, light bulb, headlights, antenna, backup light, ecm - have I missed anything?
New seats
New motor
New radiator
New alternator
New master cylinder
New transmission
New differential
Port matched intake
New tbs
New MAF sensor
New fan blade
New horns
New brake calipers
New control arms
New pitman arm
New shocks
New O2 sensor
That's it.
I hate getting into pissing matches with people. But maybe if you had worded your comment better with less of a "tone" in it the thread would have went different.
Hopefully that new fan blade didn't take much effort.
