Dead horn
Old Dec 2, 2017 | 02:34 PM
DavidandJoansVette's Avatar
DavidandJoansVette
Veteran: National Guard
Default Dead horn
Horn on my new to me 77 does not work. As this old mind remembers it worked when I drove White Rabbit on October 31. Suggestions appreciated.
Old Dec 2, 2017 | 03:08 PM
henrikse's Avatar
henrikse
Your horn relay is on drivers side engine bay by alternator. Also junction for power B12. When you depress horn button do you here relay? If do you can follow wire from relay to horn front of rad. Check for voltage here and ensure you have a good ground. (meter or testlight) If relay is not picking up you have trouble in steering wheel
Old Dec 3, 2017 | 11:18 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Guys, book mark this picture, it's helped many figure out their horn issues. http://repairs.willcoxcorvette.com/?yt=1977&s=horn
Old Dec 4, 2017 | 06:16 PM
Terminal_Crazy's Avatar
Terminal_Crazy
Excellent. I’ve got mine to look at.
I’ve just got a new spring and pin as those were missing.
And the horn.
I _should_ then have 12v at the bottom of the hole where the pin and spring sit....
Providing the relay is there, working and it has power?
I didn’t measure anything there previously but now need to check for the relay and power
Mitch
To Dead horn
