Needed spacer
Old Dec 3, 2017 | 08:06 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Needed spacer
Hey Guys,
I installed gaskets for my exhaust manifold with a buddy of mine. No issues really, but when we put it all together we noticed we had a small gap between the front bolt of the manifold. That bolt holds up the alternator and then goes through the manifold and secures to the engine. However, there is a small gap, like a nut (or spacer) is missing. Does anyone know what is supposed to be here? I don't know if it was there before we changed it out or not but we don't remember hearing anything drop and we couldn't find anything under the car.
Thanks.
Old Dec 3, 2017 | 08:13 AM
68notray's Avatar
68notray
What year? And a pic would get an answer right away.
Old Dec 3, 2017 | 08:23 AM
~Stingray's Avatar
~Stingray
I will try to get a picture later today.
Year : 1980
Old Dec 3, 2017 | 08:54 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
why did you use a gasket? there is no need for one at that area
Old Dec 3, 2017 | 08:58 PM
~Stingray's Avatar
~Stingray
Apparently 35 years later disagrees. It fixed the exhaust leak. It was already on the drivers side. Didn't realize it until I went to add it on that side.
Old Dec 3, 2017 | 10:48 PM
BLUE1972's Avatar
BLUE1972
The manifold bolts are different lengths - just as info incase you didn't know. It depends on weather they are holding A/c, Alt or another accessory.
Some years had thicker washers on the bolts to make up the length difference.
I ran a tap (bottoming) into each hole and was amazed at how much crud came out. Just used the tap to clean out the holes, not cut the thread.
Old Dec 4, 2017 | 03:37 PM
~Stingray's Avatar
~Stingray
Yes, I discovered they were different lengths when I pulled them. I kept them in order as they came off. the front also hold up the smog pump I believe.
Old Dec 4, 2017 | 03:52 PM
~Stingray's Avatar
~Stingray
Here are two pictures of what I am referencing. They might now help as it was tight in there and my cell phone is big. But you can see the gap in the bolt and the manifold in the green box. One photo is a wider shot than the other.
Old Dec 5, 2017 | 09:05 AM
stingr69's Avatar
stingr69
That location is supposed to have a stud-bolt. The exhaust manifolds were installed, torqued tight, and sent out with engine. Accessories were added later at assembly plant. I seem to remember that fastener is a stud bolt with provision for the accessory bracket installed later. Bolt in that hole is in the wrong position. Maybe you used it in a different location? See picture in next post.
Old Dec 5, 2017 | 09:13 AM
stingr69's Avatar
stingr69
...and it looks like this:
Old Dec 5, 2017 | 10:13 AM
~Stingray's Avatar
~Stingray
Can you show me a picture of the bolt I need? I will know if I put the bolts in the wrong order or if someone before me put it in wrong before I got it.
Old Dec 5, 2017 | 01:06 PM
BLUE1972's Avatar
BLUE1972
If the car is an L82 w/ac there is a compressor rear brace. The earlier cars had the A/C bracket plate bolted to the exhaust.
I would just get thicker hardened washers and go 1/16 to 1/8 thicker on the washers than the space and call it even. I use NEVER SEIZE on the bolts as I may want to remove them in the future.
Order a few catalogues - Ricks Corvette, Paragon, Zip etc - they have diagrams to help order parts and they also help identify parts.
Each year is different after 76 or so. I haven't worked on a 80 in a long time. The Chevy manual talks about French locks ? . I don't ever remember seeing any.. but most cars are not virgins...
Old Dec 5, 2017 | 01:13 PM
stingr69's Avatar
stingr69
Go to "Davies Corvette" web site and search for "713448". You can see it there.
Old Dec 5, 2017 | 04:13 PM
~Stingray's Avatar
~Stingray
Ya, I am pretty sure that is not the bold that came out. All 4 bolts were just that, bolts. None of them had threads on both ends. I guess the spacer was missing prior. Is it really that big of a deal to get it?
Old Dec 5, 2017 | 10:09 PM
Indiancreek's Avatar
Indiancreek
If you give me the size you need I can turn one on the lathe out of 4140. Send it to you.
Old Dec 6, 2017 | 07:44 AM
stingr69's Avatar
stingr69
I have no idea where to find one.
Old Dec 8, 2017 | 10:51 AM
~Stingray's Avatar
~Stingray
I might take you up on this. Give me some time, figuring out how to measure this will be the issue.
To Needed spacer
Old Dec 8, 2017 | 10:53 AM
~Stingray's Avatar
~Stingray
The more I think on this, the more I think we are talking about different bolts. If this were in the position I was thinking, there would be no way to unscrew it to take the manifold out. I will need to look again.
Old Dec 8, 2017 | 08:04 PM
Indiancreek
Sometimes you can use twist drills for a known measurement.
Old Dec 8, 2017 | 08:19 PM
tfringo's Avatar
tfringo
Default Hi
It is possible that the bolt in that location was a bolt with a stud sticking out of the top of it. No spacer involved. You just put the bolt in and torque it down and then a nut, washer and lock washer attached to the stud sticking out the top of the bolt.
This might be the situation. Good luck, Terry
Hey Guys,
Thanks.
