Speedometer Gear
Old Dec 3, 2017 | 02:17 PM
Jack605's Avatar
Jack605
Default Speedometer Gear
I replace the transmission with a TKO 500 five speed transmission and the people that did the replacement put in the wrong speed gear. So I went from a 17 to an 18 tooth gear and I have correct speed from 45-55mph. below 45 I read low on the speedometer over 55 I read high on the speedometer. I admit I am confused as to why.
Jack
Old Dec 3, 2017 | 02:50 PM
MelWff's Avatar
MelWff
you checked speeds with a gps?
have you carefully lubricated the speedometer cable with a graphite based lubricant, dont get any into the speedometer.
Old Dec 3, 2017 | 02:56 PM
Jack605's Avatar
Jack605
Yes I used a gps to check the speed, the cable was lubed and installed two years ago.
Jack
Old Dec 3, 2017 | 09:52 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Are the drive and driven gears color coded.......if they are mis-matched they will not read correctly/will wear out rapidly.
Also......my '68 speedometer head has an adjustment to tweak the reading of the needle.
Old Dec 4, 2017 | 07:00 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
how does it work?
Old Dec 4, 2017 | 07:02 AM
Rescue Rogers
Jack
thats weird, to bad you dont have another speedometer head laying around to see if the heads bad. It just make sense that thats possible
Old Dec 4, 2017 | 07:59 AM
Jack605's Avatar
Jack605
I am going to ask the question to Silver Sport where I got the five speed see what they say.
Jack
To Speedometer Gear
