Upgraded Radio
Old Dec 15, 2017 | 11:24 PM
cjkirby55's Avatar
cjkirby55
Default Upgraded Radio
So I'm wanting to keep the inside of my 77 looking close to original or at least done with GM parts. After looking at the custom audio route I remembered I have an original tape player from an 80's GM square body truck that I believe still works and I've seen some folks add an auxiliary input to these radios. My question is, is there enough room in the dash for such a large radio?
Old Dec 15, 2017 | 11:30 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Wow, must be lighter than air to float up to the ceiling like that.
If the ***** are the right distance apart and the center dial part is small enough to fit into the dash, the rest of the radio will most likely fit.....I think.
Old Dec 16, 2017 | 07:13 AM
Dynra Rockets's Avatar
Dynra Rockets
The depth is the issue. Remove the passenger side panel and measure. I was in the same boat last year and ended up getting a RetroSound because the radio I had was too long. Bonus is the RetroSound is about 1/5th the weight.
Old Dec 16, 2017 | 10:27 AM
bmotojoe's Avatar
bmotojoe
My 77 8 track measures 7 3/4" deep, 3 3/8" high. There is a mounting offset on the front area, hard to see it on your radio.
Hope this helps,
To Upgraded Radio
