early or late 1968 Corvette
Old Dec 12, 2019 | 12:23 AM
Batesgar's Avatar
Batesgar
Thanks for the info. I saw a vendor list early ***** were to vin 401400. Not sure how accurate that number is, but mine is definitely a early in the run. Now just need to find one.
Old Dec 17, 2019 | 07:54 AM
cocodrillo's Avatar
cocodrillo
Info on this link regarding trim tag date identification for build date....and lots of other cool information:
https://www.corvsport.com/1968-c3-co...mKpvMrUGZNuJaE
Old Dec 17, 2019 | 09:46 AM
PJO's Avatar
PJO
Veteran: Marine Corps
3 different ***** were used in 68 production.
Vent controls are present only on non-air-conditioned cars. All 1968 and
1969 Corvettes up to at least S/N 14,000 use two small chrome
rectangular *****. The first design said VENT on the front side with
parallel grooves on the back. The later design reads
VENT in raised shiny block letters on the side facing outward when
closed and OPEN on the reverse against a black background.
Very late 1969 cars use round smooth, shiny black plastic *****
with the word CLOSE and an arrow in white on a flat surface..
They are secured to black-phosphate plated levers with a hexset
screw.
Coffee can verses pie pan
The pie pan was not used until about 31000 VIN in 1969
Old Dec 17, 2019 | 09:54 PM
suprspooky's Avatar
suprspooky
I have a 68 vert (Aug build) that by most indications (vent *****, low seat release, door panels), it also has the Frame Kick up braces. Never will see judging tho.
Old Dec 18, 2019 | 10:39 AM
Batesgar's Avatar
Batesgar
My 68 convertible is vin 400650 (Sept 67 build). Didn’t think they built 68s in Aug 67, what’s the vin?
If earlier then mine, what was the status of the wiper override **** next to the headlight and wiper bypass valves under the dash?
I have the **** but it’s not connected and I don’t see the wires. Maybe was installed but not used early in the 68 builds??
Old Dec 19, 2019 | 04:26 PM
Mike Baker's Avatar
Mike Baker
Dang 400650 is early. It must have all the fun unique '68 things. Does or did it have the white wiper pump cover?
Old Dec 20, 2019 | 12:57 AM
Batesgar's Avatar
Batesgar
I’ve seen a list of early 68 Vettes items, but not sure what the white wiper pump cover entails. I purchased the vent ***** that are vent/line pattern and match 1 of the 2 on the car....but the ones I bought have a silver line pattern while mine is silver and black. Anyone know which is correct?
Old Dec 20, 2019 | 09:01 AM
PJO's Avatar
PJO
Batesgar
Early cars have been seen with the Vent pointing to back of the car with with horizontal bars above. But we as a group do not have a definitive change over date for the installation of the 2nd design ****.
As for the White pump cover it is the top and housing of the washer pump with the 3 ports and rubber hoses going to it. It yellows with age.
Old Dec 20, 2019 | 04:43 PM
Batesgar's Avatar
Batesgar
It has the white wiper housing.
As for the vent *****, are the horizontal lines silver or silver/black?
Old Dec 20, 2019 | 05:08 PM
PJO's Avatar
PJO
Should be Chrome only 2nd is chrome with black background.
Old Dec 21, 2019 | 06:41 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
it should have one brown wire with a white stripe going to it. If it isnt there, it is probably going straight to ground. It is used to interupt the ground path and was a cause of many dead batteries. A PO may have been fed up with it an just bypassed the switch
Old Dec 21, 2019 | 08:24 AM
Batesgar's Avatar
Batesgar
Thanks, previous owner must have not only installed one of the vent ***** as vent/open...but also painted the line side of the second **** with a black background behind the silver lines.
I purchased the correct ***** that are vent/line pattern, with only the vent side in the black background.
Kind of expensive...as are most of these 68 parts.
Old Dec 21, 2019 | 08:29 AM
  #33
Batesgar's Avatar
Batesgar
I will look for the brown/white stripe wire today when I crawl under the dash today. I did see one wire tied to ground that didn’t appear factory...just can’t recall it’s color.
If that’s the case, not sure if I will reconnect to be factory or leave alone and deal with alternatives to change wiper blades by stopping action mid stroke.
Old Dec 21, 2019 | 11:34 AM
  #34
pltmgr's Avatar
pltmgr
My 68 had the brown/white wire attached to the over ride switch but the ground to the switch was disconnected, making it inoperative. There was a non factory ground to the wiper wiring attached to a valve cover bolt. When I removed this this ground the wipers wouldn't work until I reconnected the ground to the wiper override switch.
I'm not trying to confuse things but providing an example of issues that may exist in a 51 year old vehicle.
Old Dec 21, 2019 | 11:13 PM
  #35
thatcorvetteguy's Avatar
thatcorvetteguy
Don't forget the wiper switch **** letters where painted blue.
Old Dec 22, 2019 | 12:20 PM
  #36
20round's Avatar
20round
C2 of Year Finalist (stock) 2019
also a early car will have 2 piece pillar corner trim were the t-top locks, or the conv top locks..both my 68 roadsters 12/67 and 1/68 have these 2 piece corners...troy
Old Dec 22, 2019 | 08:02 PM
  #37
Mike Baker's Avatar
Mike Baker
Thank you for the reply. Only white pump housing cover I've seen is the one I have. Wasn't sure if it was correct or not. Vin is in the mid 1500's. It's discolored and very brittle. PO stuck a finger or something through it.
To early or late 1968 Corvette
Old Dec 23, 2019 | 05:09 PM
  #38
Batesgar's Avatar
Batesgar
So, I opted to connect the brown/white stripe wire to the switch (was connected to a ground) after testing switch and confirming it worked.
The switch only has 1 wire and gets its ground via its bolting to the bracket.
The **** has no letters.
Old Dec 23, 2019 | 06:24 PM
  #39
Rescue Rogers
the wiper switch **** was painted, the override **** wasnt
Old Dec 23, 2019 | 06:36 PM
  #40
Batesgar's Avatar
Batesgar
Thanks, the square wiper switch letters are painted in blue and the round override **** in just black.
