Rear frame cleanup.
The things you find out about your car when you start to take it apart. The battery box must have been destroyed at one time. They took another one and slid it down into it and riveted it together. I glassed it all together today. U joint must have went and axle hit it.
It takes me one day to disconnect everything and I typically lift the body on day two. I use six points of support including the four body straps which I designed and had built just for this application on the gantry; and two nose supports which hold the nose in the correct location and position while the body is hanging and awaiting the return of the chassis.
This is my 72 race replica I did this past summer.
Sitting on a chassis built to serve as a body dolly while I work on my chassis. Best body dolly around in my opinion.
Chassis is easy to work on with the body up and off.
This is the 77 coupe I am working on now. I put it back on the rolling chassis donor while I restore the cars existing chassis. That work starts soon for the winter.
This body is now sitting on my body dolly chassis and my original chassis has been taken apart; media blasted; reinforced; modified; and is now powder coated and ready for reassembly. It will move into the center bay in about two weeks. I am now gathering and preparing all the parts to put it back together which I am detailing in another CF thread.
Several have seen this and been a part of it with me here at my home.
I just put the 77 body I have back on a donor rolling chassis so I can move it off the lift when I want to.
I am 64 and I do these by myself. If you have a lift and a gantry you can do lots of jobs fairly easily.
Just another option for you to consider.
Let me know if I can assist in some way.
Best regards,
David
Well you know what happened next
which led to
which then led to
But there isn't any rust on it anymore
LOL
But I am glad I took off the body
Glenn in San Diego
David,
I am very impressed!
I have a Bendpak 4 post lift but am very afraid to do the body off route even though I know it would come out much nicer and once off the frame easier. I am afraid I might somehow warp the body by not properly supporting it. Plus needing more room to store the body. Like others have said, I too am in the middle of whatnwill be and already is a years long resto with other cars in the garage in the way.....
And I'm not getting any younger.
I have one Vette on the lift that I removed all the front end bracing out of alomg with many other parts and powder coated, cleaned and bagged for reassembly after paint. Trying to do it in some kind of order. However, I noticed the nose started to droop about a half inch within a few months so I supported it by carefully strapping it up to the ceiling. My point is, doing it with the body on didnt prevent what I was concerned about anyway.
I like the gantry. The idea of supporting it off the ground makes so much sense as its out of the way. You gave me some needed inspiration. Right now I'm stuck with too many cars to do anything along with the crappy weather. Once I sell off one of the cars (68 Camaro, keeping the Vettes) I will have the room and will want to reach out to you to see exactly how you set up the gantry and how you supported the body. It looks like a great way to go.
Ed
which led to
which then led to
LOL
Glenn in San Diego
If I take the body off i will never drive the car again. I have a lot of projects ahead of me. I have work in my house that needs to be done, I have my 67 GTO that I would like to get done.
You also took a little more than 8 bolts out.
I am just going to clean up the rear of the frame. I have 3/4 of the frame cleaned. The last vette I did a frame off on took 4 years. I did that when I was in my 40's. Going from 40 to 50 is a little different than going from 60 to 70. I don't have the same energy I had when I was in my 40's and early 50's.
I also don't have the room anymore. I have my GTO in one side and the vette on the other.
My 70 was a very clean car to start with, the mechanicals were gone through before I bought it but I wanted to pull the rear suspension completely out to make sure things were up to snuff. After much masking, taping and wrapping things in blankets and drop cloths. I went after the rear part of the frame from the front of the doors back with the blaster seen in this picture. The car looks body off restored after that operation. Great improvements can be had with a little ingenuity.
The pic of my 59 frame was the only one I had handy showing the pressure blaster. I farm out big blasting jobs like entire frames. Not worth the time and abuse on my compressor.
BTW, if you have a siphon blaster, that is no where near as good as a pressure blaster, had both.
I still have the car and this was about 13 years ago. Still looks great but I don't get the car wet.
Attachment 48241514
Attachment 48241515
Attachment 48241516
Attachment 48241517
Attachment 48241518
Attachment 48241519
Best regards,
David
Very nice offer David!
Boats have been around longer than the corvette... however, if we all think about this for one tiny moment, we might just get it. The name of the car "Stingray" was derived from an aquatic fish. Because of the way it moved through the water with sleekness(is that a word?) So, the designer of the stingray turned to the boating industry to get some ideas on how to create a car named a "stingray" that looks like one too.
So, now that I think we are all getting the picture here, maybe you should talk to boat people to see how they take care of their fiberglass boats?... with this say, I know myself from owning "both"(boat and corvette) that boat folks love to strip the bottoms of their boats by "sand blasting crushed walnut shells" you can adjust the air pressure so that it does NOT affect the fiberglass and yet strips everything else away.... including barnacles. Now I know none of you have taken your vettes out for a swim, and they don't have barnacles on them.... but they do indeed have things clinging to the underside that are just as nasty.
So with this said, I hope I was able to introduce a rude awakening!
And if you're as lazy as me, this would be an option
So, ARGH! maties! Chins up (if your car is on a lift) and blast away!
