The rear "pin" is changeable to suit the different styles, problem is it's easy to make the later "pin" as I needed to but harder to make the triangle receivers needed for the earlier ones.
There was someone else who had a set of them and also needed the early style fittings, strange thing is I think they were in Australia...
M
Here's the pins, mine came with the triangle ones but I needed to make the later bullets for my setup
When installed, are those retainers spring loaded? Thanks
Yes
The little **** screws into the side of the pin(s) and slides in a slot that restricts how far in/out the pins go.
Spring behind everything pushes it out to engage the triangle or receiver hole.
Not a tremendously strong spring but the force isn't in that dirrection
M
emailed the seller just after you posted the links, asking for a shipping quote as there was no postage listed, get reply this morning, "SOLD"
they sold for 365$us.
i'll just give up, lifes too hard.
Don't give up! Set a search to notify you when some are available. I waited and watched a LONG Time before I got my roof panel carrier louvers, and "A/C Strategies " book.
Reason: Misspell
