Hidden windshield wipers . . . .WHY ! ? ! ? !
Old Jan 21, 2019 | 05:15 PM
pltmgr's Avatar
pltmgr
My DD was a 68 in upstate NY in early 70's. Don't remember ice being a problem. Concealed headlights and wiper doors look slick in my opinion but having spent many hours troubleshooting/fixing these systems not sure why they are vacuum. I like them better when they are working.
Old Jan 21, 2019 | 07:02 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Styling!!!!!! It creates beautiful uninterrupted lines!!! Of course mine works and I have a truck to drive in the snow so it easy for me to say how cool they are!!! Remember you are looking at 50 year old car designs!! You cannot justifiably compare them to current designs. Ike
Old Jan 21, 2019 | 07:16 PM
loup68's Avatar
loup68
Army
GM engineered both the headlights and the wiper panel to be able to break through three eights of an inch of ice. I had to drive my 68 coupe in Cleveland for four and a half years after a divorce, so I know they did that!
GM went to the vacuum system for the headlights after all of the trouble with the mid year (63-67) electric motors and gears. Lou.
Old Jan 21, 2019 | 08:12 PM
BLUE1972's Avatar
BLUE1972
reasons for the "hidden" wipers
- Lower drag - sounds stupid but today it counts (CAFE Standards)
- Less debris hitting the blades, keeps the blades out of the sun
- styling - blades look ugly
- back in the day was considered cool - advanced
Old Jan 22, 2019 | 05:46 PM
Tonio's Avatar
Tonio
Wish I could figure out why my wiper door won’t open. I hate this vacuum system! Argggggg!
Old Jan 22, 2019 | 06:28 PM
BLUE1972's Avatar
BLUE1972
it's really simple, use Wilcox diagram,
With the engine running:
Turn the wipers on, take a thin long bladed screwdriver and push down on the "air switch" under the passenger side wiper arm - if it lifts the switch is out of adjustment.
If not apply vacuum to the canister - see if the door opens.. if it works next is the the air switch under the passenger fender. - keep going ….
Old Jan 22, 2019 | 06:41 PM
Tonio's Avatar
Tonio
thanks Blue! I’ll try this out this weekend! Much appreciated.
Old Jan 22, 2019 | 07:06 PM
pltmgr's Avatar
pltmgr
I just fixed mine. Cant say it was easy to figure out and some components under dash are difficult to reach. Tons of info on the forum and keep in mind there could be electrical issues causing non operation.
Old Jan 22, 2019 | 11:15 PM
BLUE1972's Avatar
BLUE1972
When trouble shooting the system - just remember it was designed to fail open. The main function of the "switch - air / vacuum" under the arm was to prevent the door from closing on the wiper arm. I have seen systems with hoses reversed on the control valve (under the fender) and thus it will drive you nuts. The Wilcox diagram makes it easier to trouble shoot.
You can also pull down the valve on the right side under the steering column to open the door. The electric valve is supposed to be on the back of the tachometer.
