Question on voltage - start vs run
Old Jan 28, 2018 | 08:06 PM
DAC516's Avatar
DAC516
Default Question on voltage - start vs run
I have a 1969 L46 350 with a 4 spd. I bought the car in non-running condition and trying to get it back on the road. I have the original points distributor and would like to upgrade to HEI. I bought an HEI distributor from Skip White Performance (https://www.skipwhiteperformance.com...6515-bk_83450/). I ran a new wire from the IGN terminal on the fuse box to the BAT terminal on the distributor. I disconnected the wire from the starter. I taped up the wire that was on the coil side. I removed the old coil and the ballast resistor. The problem is I have very weak spark. With the ignition switch in the RUN position, I have 12 volts at the BAT terminal. When in the START position with the starter engaged, it drops to 9.5-10 volts, which I believe is not enough for the HEI. This is across the entire system. Even taking a measurement at the alternator, it drops to 9.5-10 volts. What am I missing? How do I get 12 volts to the HEI when the starter is engaged? Perhaps the starter has a short in it?
Thanks,
David
Old Jan 29, 2018 | 07:05 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thanks,
David
A few items:
1) How do you know your spark is "very weak"?
2) What size/age is your battery? Cranking an engine is naturally going to drop the battery/system voltage due to all the current being drawn by the starter.
3) A genuine HEI is designed to operate down to 6 volts (I have no idea what the Chinese ripoffs work down to.). The spark output should still be fine during cranking at 9.5-10 volts.
Old Jan 30, 2018 | 10:21 AM
DAC516's Avatar
DAC516
Originally Posted by 69427
A few items:
I pulled #1 cylinder spark plug and let it rest on a ground. I watched the plug as someone else cranked the engine. I also tried a Lisle induction spark tester, but it showed no spark.
New Interstate battery from Costco in November. I still have the original battery cables. Do battery cables go bad?
Thanks for the comments!
Old Jan 30, 2018 | 10:42 AM
pthor's Avatar
pthor
From: I don't do cities N/W Montana & Nor California
I have recently had to tackle this when I installed my New MSD system on my new rebuilt motor.
I don't know all the technicals but my old positive coil wire that produces 12 volts when the key is on is powering my MSD system fine at this point. I don't know if the voltage drops since it starts in my motor fine I haven't bothered to get into that.
Old Jan 30, 2018 | 11:06 AM
ENCSDOUG's Avatar
ENCSDOUG
I just installed a new Hei/Msd distributer after running one that came with the stroker motor. I have no issues. I agree with 69427. How old is your battery/size? What are the readings while the motor is running on the alternator verse the start reading from the battery?
Old Jan 30, 2018 | 11:09 AM
DAC516's Avatar
DAC516
How old is your battery/size? 2 month old Interstate battery
I haven't been able to start the engine yet.
Old Jan 31, 2018 | 10:37 AM
ENCSDOUG's Avatar
ENCSDOUG
During start, you should have 12v and will drop during start. Once the motor is running, you should have at least 13v to your battery which means your alternator is recharging your battery.
Old Jan 31, 2018 | 01:31 PM
REELAV8R's Avatar
REELAV8R
That kind of voltage drop during starter engagement would be normal and should not affect the HEI to a degree that would prevent starting.
Old Jan 31, 2018 | 02:51 PM
Mr D.'s Avatar
Mr D.
Understand you have a HEI but;
On a 69 with stock unmolested wiring you will have less than 12V in the run position and 12V (or what the Batt is holding) in the start position.
Also you have two wires going to the coil 1) run voltage & 2) start voltage both are powered independently via the ignition switch.
Old Feb 12, 2018 | 10:58 AM
DAC516's Avatar
DAC516
Just as an update on this thread, I received a replacement HEI distributor under warranty. With the new distributor installed, the engine fired right up. So, all is well.
Old Feb 12, 2018 | 12:53 PM
pigfarmer's Avatar
pigfarmer
A bit late but yup, just measured it recently. Two wires. 12v at start, about 9v to run. I only looked at it because I replaced a Holley electric choke and the directions specifically said not to pick up voltage at the coil for that reason.
To Question on voltage - start vs run
