RPM needle stuck
Old Feb 4, 2018 | 02:05 PM
Tbone4432's Avatar
Tbone4432
Default RPM needle stuck
The rpm needle is stuck on 4500 rpms when idling and when the engine is shut off. Any idea whats causing it to get hung up? It's a '77.
The engine had the following work done...timing chain, pulled dist. when I painted the block, new cap and wires.
Old Feb 4, 2018 | 04:38 PM
george2066's Avatar
george2066
Default prob need a new tach filter
willcox website has info and testing
Old Feb 10, 2018 | 10:35 AM
lvmyvt76's Avatar
lvmyvt76
did you get an answer to your question?? you are talking about the tachometer, right?
Old Feb 11, 2018 | 07:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sounds like the tach board is dead... Why, because even if you didn't have signal, when you power up the car the tach should reset to zero.
Willcox
To RPM needle stuck
