carb work
Old Feb 7, 2018 | 01:26 PM
demmadog's Avatar
demmadog
3rd Gear
Default carb work
1978 350 sb, carb is tired, should the Q-jet be rebuilt or replaced, if replaced with what ,Holly, Elednbrock or?
L82 with headers and sidepipes, no work done to engine that I can see other than pollution stuff removed.
Old Feb 7, 2018 | 03:09 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
i would stay stock roch.
even so, it is a money thing.
if,if, your original is,, and not beyond repair,
it came be rebuilt.
member named, lars ,rebuilds them better tan stock
Old Feb 7, 2018 | 03:14 PM
shenango's Avatar
shenango
The Qjet is real easy to rebuild if you have moderate or better skills. Get a good kit from quadrajetparts.com, NAPA or a speed shop and go at it. No special tools required and you will learn a lot from the experience. If you would rather have it done professionally then Lars, on this forum, may have the time to do it if you ask.
Jerry
Old Feb 7, 2018 | 03:17 PM
lvmyvt76's Avatar
lvmyvt76
you don't need a new crb, IMO, you just need it overhauled if no one has monkeyed with it, (like tried to upgrade it, or put in larger jets etc). A rebuild at least is in order, if the carb is the problem. What makes you think the carb is the problem????
Old Feb 7, 2018 | 04:51 PM
SteveG75's Avatar
SteveG75
"99% of "carb" problems are really ignition issues." - Lars
Old Feb 8, 2018 | 11:35 AM
demmadog's Avatar
demmadog
3rd Gear
started with carb, E-mail for Lars or contact, where is he located?
Old Feb 8, 2018 | 11:38 AM
Big2Bird's Avatar
Big2Bird
Lafayette,co.
V8fastcars@msn.com
To carb work
