power problem
Old Feb 12, 2018 | 03:26 PM
venicesteve's Avatar
venicesteve
Cruising
Default power problem
I have a 1975 coupe and I do not have any power at the instrument fuse at block.Some one jumped the fuse by soldering a piece of wire across it. also does tachometer run off that circuit.Can it be solved
Old Feb 12, 2018 | 07:36 PM
Peterbuilt's Avatar
Peterbuilt
Default Is the TL fuse good?
The 'Taillight' fuse powers the instrument fuse.
Old Feb 13, 2018 | 06:45 AM
venicesteve
Cruising
thank you for information I will check that out
Old Feb 13, 2018 | 09:52 AM
lvmyvt76's Avatar
lvmyvt76
How are you checking them , with a meter or just looking at them???
Old Feb 13, 2018 | 03:12 PM
venicesteve
Cruising
a test light just ordered a meter
Old Feb 13, 2018 | 09:51 PM
lvmyvt76's Avatar
lvmyvt76
a test light should work just fine. I wonder why they soldered a wire across at the fuse block, that would take away any protection provided by a fuse. Were they tired of replacing the fuse?? did they have extra draw on the fuse by adding something like a different radio or something?? Is the car fully stock in the dash area, or are extra things hanging from the dash area??? different gauges or something, we need more information here!
To power problem
