torque converter cover
Old Feb 16, 2018 | 01:36 PM
jcorvette72's Avatar
jcorvette72
Cruising
Default torque converter cover
im reassembling my 75 corvette with a383 crate engine...for some reason the torque converter cover 3 holes line up to the transmission. the right side bolt hole does line up with the trans bellhousing...automatic.
is there a difference in different years.?...i have a 72 auto trans with a zz4 and that one lines up just right.
i installed the starter on the 383 and it lines up fine too..
the only difference in the original engines from the late model engines is the one piece rear main seal.
i dont think that is the issue though.
thanks for any help.
Old Feb 16, 2018 | 03:30 PM
MelWff's Avatar
MelWff
not to clear what you are saying the cover has 4 bolt holes all of which attach to the transmission bellhousing. All C3's used the same cover.
Old Feb 16, 2018 | 04:40 PM
jcorvette72
Cruising
one bolt hole on the right side does not line up with the hole on th transmission the cover hole is about an inch from lining up.
Old Feb 16, 2018 | 04:43 PM
MelWff's Avatar
MelWff
are there any part numbers on the cover?
which transmission do you have?
Old Feb 17, 2018 | 07:03 PM
jcorvette72
Cruising
turbo 400... no part number
To torque converter cover
