69 speedo gear
Old Feb 25, 2018 | 09:42 AM
STRICK9's Avatar
STRICK9
Cruising
Default 69 speedo gear
I have a 69 427 3 x 2 with the original Muncie four-speed. Sometime during the restoration the driven gear on the speedo cable got lost I have the original 3:36 diff- Which color gear goes in this cable Thanks for the help
Old Feb 26, 2018 | 04:58 PM
MelWff's Avatar
MelWff
how many teeth on the drive gear, 7 or 8?
what is the diameter of your rear tires?
for a 7 tooth drive gear and a 27" tire and a 3:36 rear the formula is 8*3.36*747/1001=18 tooth driven gear
for a 8 tooth drive gear and a 27" tire and a 3:36 rear the formula is 8*3.36*747/1001=20 tooth driven gear
Old Feb 27, 2018 | 08:08 PM
STRICK9's Avatar
STRICK9
Cruising
Thanks MelWff, 7 teeth = the brown driven gear w/ 18 teeth. Thank you for your help
To 69 speedo gear
